Knock sound when turning steering wheel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Silver_Bullet_2012, Oct 22, 2022.
  1. Silver_Bullet_2012
    Silver_Bullet_2012 Junior Member
    Santa Barbara
    Small knock sound when turning steering wheel(see attached clip).
    https://youtube.com/shorts/CzZ4H84yHCA?feature=share
    So far I have replaced both struts, as well as ball joint, and sway bar link on driver side. I order sway bar link and thought it was a set, but it was just one, so I put it on the drivers side. I’m wondering could the link on the passenger side be causing this? Waiting for package to arrive.
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Rack ends . Gently rock steer wheel car off . Think think sound just barely rocking S wheel just past Freeplay
  3. Silver_Bullet_2012
    Santa Barbara
  4. Tombukt2
    13,867
    2,520
    Durham NC
    Yes you tightened to set bolt on the yoke. Keep an eye on it because that noise may come back usually the yolk bolt should not be any kind of loose it's just holding onto a spleen shaft into a hole that matches but good job.
