Knocking Lack of power issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brianblang, Feb 19, 2022.
  1. brianblang
    brianblang New Member
    29
    GA, USA
    Greetings, everyone. This is my first post but I have benefited tremendously from lurking in here in the past. I have read all the posts I could find that I think are relevant to this matter and I could use some help.
    This is the noise heard with my GEN2 2006 Prius with 293K miles. As expected, it burns oil. I have had no issues at all with this car with the exception of needing to add the resistor to my dash and regular battery and tire replacements. I have no engine codes. However, I did pull a P0420 "catalyst" code before I began my troubleshooting. I cleared it and it has yet to reappear for 60 miles. I have now replaced the Spark plugs, Coil Packs, Fuel injectors, filled up with premium fuel with seafoam, and topped off the oil with Lucus oil treatment and it made no difference. I have since reinstalled my original OEM coil packs and fuel injectors. The noise sometimes goes in and out as I attempt to observe it but the noise is not limited to a cold start. I can hear it when driving around town but it is too faint to hear on the highway. It does seem to speed up with higher RPM. It is obviously present while idling and Driving but not in neutral or reverse. It goes away once the car begins to run on battery. This video was taken while it was in maintenance mode. I have attempted to listen with a mechanic's stethoscope but I could not tell where it was coming from. Other symptoms include an immediate loss of power in acceleration thus also creating low gas mileage. Loss of power can really be felt while going uphill on the interstate. I can get up to speed but it takes more power to get it there. I have let my oil run low in the past and it was 2.25 quarts low when the issue(s) started. I topped it off with Mobil 1 high mileage and then later siphoned out a quart to add the oil treatment but did not notice a difference. Other observations include coolant levels are stable, no white smoke coming from the tailpipe, and my oil is not milky. I do not mind getting my hands dirty to fix this. Any help would be appreciated. Thank you.
  2. brianblang
    29
    GA, USA
    While I wait for my post to be approved, I just wanted to add that even though I have may eliminate several of the easy low-hanging fruit repairs, I still have an interest in knowing exactly what is wrong. That being said, anyone that is of the opinion that the engine is ruined, I would like to know specifically why you think that is the diagnosis and exactly what is wrong. Also, is it worth investigating the oil control valve filter? I have seen several people theorizing it would cause these issues but I have not seen anyone affirmatively say that it was the reason for their problems.
  3. JC91006
    16,937
    8,647
    You’ll need a new engine. Luckily they are cheap to buy.
    293k miles, valve ticking, and burns tons of oil. Sign of a worn motor
    #3 JC91006, Feb 19, 2022
    brianblang likes this.
  4. brianblang
    29
    GA, USA
    Thanks for the input. Can the specific issue be determined by the video sound and description? Also, does a noisy valve create a lack of power or am I looking at two separate issues?
    thanks forthw
  5. JC91006
    16,937
    8,647
    Lack of power comes from a worn engine with 293k miles on it. Did you know the 2004-2005 Prius odometer only goes up to 299k miles? Only in 2006 did they change the odometer to go higher than 299k miles. It won't go higher than that because the engineers at the time didn't think the car would ever go that high.
    An engine that's deprived of oil will go south really quickly. At your mileage, it's had a good run and it's time to get another engine.
    edthefox5 likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    If it has the original hybrid battery that’s really tough on the engine too. The hybrid battery contributes the major power contribution so when that goes away from old age the engine has to work twice as hard. You have to push the engine much much harder to make up for that lack of power.
    The hybrid battery power failure is so slow over the years you hardly notice it till it gets to where your at now where you cant even go up a hill without flooring it. And mileage is horrible.
    Combine that with very poor oil maintenance is a death sentence for a high mileage motor.
    Run a G2 motor really low on oil a few times it’s nitey nite
    For that motor. It toasts most motors.
    so my point is you probably will need a new hybrid battery in addition to anew engine.
  7. brianblang
    29
    GA, USA
    Thanks again for the replies. I understand that 293k miles is a lot of miles and the most effective thing to do "may be" to replace the engine. With that understanding, I am specifically looking for what is wrong with the engine based on the symptoms I am describing. This was not an issue of an engine wearing out over time but a problem that happened within a day. Knocking one day, when it was not the day before accompanied by immediate performance issues that were not present the previous day. I went on a 45-mile trip and the performance was cut in half by the end of the voyage. Also, I checked the hybrid battery life with Dr. Prius and I currently have 59% life left with everything testing fine, so I am good there. I have read several posts where someone has presented an issue and the advice was to replace the engine because it was old only to discover the problem was as simple as a plug or coil pack. Respectfully, if you are telling me I need to replace the engine because it sounds like I have attempted all of the known solutions available and further diagnosis is futile, I would be willing to accept it easier than the engine is simply worn out without me knowing exactly what the issue is.
    1. Does the noise sound like a bucket valve issue or something else?
    2. Would a noisy bucket valve cause immediate performance issues(MPG cut 50%)?
    3. Could I be experiencing a "catalytic converter" issue due to the excisive burning of oil and the fact I had pulled the "cat" P0420 code?
    Thanks all for the input. I am sure everyone understands why I would want to eliminate all minor issues before just replacing the engine simply because it is old. I learned to fix my MFD with a 50 cent resistor and my hybrid battery by replacing one cell for 60 bucks by reading posts provided by Priuschat members, so I have been positively conditioned to exhaust resources before giving up without knowing what the issue is.
  8. brianblang
    29
    GA, USA
    Thanks again for the replies. I understand that the lack of responses in this post may be due to the lack of my realistically available options for the issue. I am willing to relegate this Prius to only driving around town and eliminate any long trips due to the existing noise. I understand that an engine with 293k miles that knocks and burns oil is on its last leg. I am not solely depending on the car and my current desire is to get every mile possible out of it before it will no longer run and I am required to scrap it.
    My problem is that I still do not understand specifically what I am dealing with. What component is actually causing the noise? If it is a noisy rod or valve, would a thicker oil or specific oil brand help lubricate the problem component enough for me to get an extra 10K miles out of it? Does a loose or noisy value or rocker cause immediate loss of power? Could the sudden loss of power be due to a stopped up catalytic convertor having to deal with all of the burned oil? Is there anything else worth checking such as the VTT oil control valve before I give up?
    I appreciate your help. Even if I am unable to solve the issue I hope to be able to at least earn from it myself or create a chronicle that could help others with the same problem that stumble across this post.
  9. JC91006
    16,937
    8,647
    There are many things that are contributing to the loss of power. Can't pinpoint an exact issue without tearing your engine apart.
    VTT oil control valve and filter are easy to get to. You can see if that is the cause of the power loss issue. The knocking on the engine won't go away if you address that filter and valve.
    Throwing money at this thing is really just throwing money at it, it will not solve/fix the car without significant overhaul of all the worn parts. The easiest and cheapest way to get this car running again is to put in another lower mileage good engine.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Your engine noise is very bright and sharp, and seems to be at crankshaft speed. If this was caused by a sudden fault with the valve train, I can't imagine anything that would make that much noise without causing a loss of compression (and a misfire code)- and the noise frequency would be some slower.
    . If it was a failure of the VVT actuator (intake cam sprocket), again I would expect cam timing codes.
    I would think that the noise is being picked up by the knock sensor, and that the ECM is retarding ignition timing in a (futile) attempt to make the "knock" go away- causing your loss of performance. You would need to look at engine data with a scantool to confirm this.
    So what could your noise be? Doesn't sound quite right for timing chain slap. Might be a failed damper between the engine and trans (which I think fits with your observations that it stops in neutral or EV mode). Another thought would be that a piston has a broken skirt.
    strawbrad likes this.
  11. brianblang
    29
    GA, USA
    This is some good information. I will need to do some research on learning about a damper failing. I assume if a piston skirt is broken, it can be verified by finding it in pieces at the bottom of my oil pan. Please correct me if I am wrong. '"JC91006" is right that I do not want to throw money at a sinking ship. What will be the eventual outcome of not doing anything and driving the car 5 to 10 miles a day without fixing either a failed damper or broken piston skirt?
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Failed VVT circuit would not make the engine knock it would just be a dog with bad acceleration. And throw a code.
    Sounds like a bad cop. G2 motor is crazy loud with loss of cylinder,
    Many youtubes on that. But would have misfire code P3001 to 4
    Given mileage it may be getting ready to throw the #2 piston out the side of the block. Oil starvation. We have seen many of those on this site. Youtubes about that also.
    Used motors are cheap.
  13. brianblang
    29
    GA, USA
    I do not think it is a Coil cop. I replaced the coils with no positive result.
  14. brianblang
    29
    GA, USA
    Would a rebuilt ICE come with a nonfailing damper if I end up getting a rebuilt engine?
  15. brianblang
    29
    GA, USA
    So I pulled out of the driveway this morning and I finally got my first codes. P3190 and P0A0F with the red triangle of death. I promptly put it in reverse and parked it in the driveway. I have not had a chance to replicate the codes. They do not help me but maybe the codes can help affirm one of the potential issues we have already considered in this post. Again, my desire is not to diminish the valued opinions calling for a new engine. I just want to take advantage of the learning experience before it gets replaced.
    1. Do these codes help us with the diagnosis at all?
  16. JC91006
    16,937
    8,647
  17. brianblang
    29
    GA, USA
    #17 brianblang, Feb 25, 2022
  18. brianblang
    29
    GA, USA
    Well, I am no wiser as to what was the issue with the old engine but I did take the advice of the forum and replaced the ICE. I got it from a local junkyard for 300 bucks. I followed the directions from the Gen2 Prius Engine Removal Guide - Out the top of the engine bay | PriusChat Out of the Top engine removal post and had no problems. However, the junkyard engine did have some water on top of the plugs and gave me quite a bit of rattle until I got them replaced. I also had one bad fuel injector. Now that I have it running properly on the ICE side, My 7th cell in my battery is failing under load and will have to be replaced. Getting there! The only other time I have had a faulty battery was when I elected to let the car sit during the first month of lockdown and when I started it up about 3 weeks later I had some bad cells. I replaced them and no problem until now. It took me about 3 weeks to finish the engine swap and now I have a battery cell going bad again. I had run the Dr. Prius life test before the swap and everything was good. Is there a connection between the car setting and not running for 3 weeks and losing a cell?
    edthefox5 and Another like this.
  19. JC91006
    16,937
    8,647
    Hybrid batteries should not sit for long periods, they self discharge. This is especially important when the battery is old and over 8 years old
  20. strawbrad
    953
    1,007
    Absolutely! Letting a hybrid battery sit unused is the worst thing you can do to it. Cells die through self discharge. Daily driving keeps the cells with high self discharge in working condition. Once a cell drops off from self discharge it can not be recovered.
    +1+1+1+1+1
    I think this was the original problem. If you still have the original engine remove the oil pan to check for piston parts.
