1. Randy_kirkpatrick
    Randy_kirkpatrick New Member
    PA
    My 2006 Prius makes a loud knock when I stop and again when I start to move. We have replaced the cv axles, wheel bearing hub, and sway rods. Still making noise.
    My mechanic is out of ideas and has no idea where it is coming from.
    Can anyone help point me out?
    Thank you
    Randy K
  2. Randy_kirkpatrick
    PA
    this is the sound
  3. JC91006
    16,936
    8,647
    it seems the sound happens at the exact time the tire makes a full rotation.
  4. Tombukt2
    Tombukt2 Senior Member
    13,859
    2,519
    Durham NC
    And I'm assuming it'll do the same going forward too correct? I mean a faster ticking noise comes from the wheel bearings many times when they're starting to go but a one clunk like that not so much and like the other poster said it seems to be exactly as the time the wheel is coming around again so I don't know if maybe your lug nuts are tightened incorrectly the wheels not all the way on seated but the lug nuts seem to be tight something along similar lines possibly and as the tire rotates around it clunks as that one spot tries to seat. Or something along those lines You could check backing plates on your brakes but I kind of doubt it doesn't sound like that.
  5. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    Change the transmission fluid after running car for a while with a high powered magnet attached to the drain bolt...
