Koni, Bilstein, Sachs don’t make struts/suspension for Four Touring?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Prius33704, Apr 9, 2021.
  1. Prius33704
    Prius33704 Junior Member
    Central Florida
    TIL some cars have struts and some don’t.
    The only option came up on tirerack.com is KYB which I read isn’t good.
    Why so limited in options? What other brands should I look for?
    thank you.
    signed
    Clueless
    2017 Four Touring
  2. Leadfoot J. McCoalroller
    7,844
    7,310
    Pennsylvania
    2018 Prius c
    As far as I'm concerned KYB is the best for these cars. They were the OE supplier to Toyota and the failure rate on the parts is quite low.
    I don't know what you've been reading but I suspect it's just noise.
    I probably would not choose Monroe or Gabriel, and Sensen is to be avoided like an infection.
    Prius33704 likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    At only 4 years old, why do you think you need new shocks/struts ??
  4. Prius33704
    Central Florida
    It has 70k miles on it.
    Went over shallow dips in the road, like manholes, and the car lurched.
    I feel the shallow bumps on my bums.
  5. sam spade 2
    7,035
    2,798
    2017 Prius c
    Reasonable assumption then.
    Good luck.
  6. Mendel Leisk
    40,540
    Any truth to this? I’m clueless too, but as far as I know they ALL have shocks, you’re only replacing shocks, and your options are various aftermarket OR Toyota parts.
    can’t have that lol.
    #6 Mendel Leisk, Apr 10, 2021
  7. Leadfoot J. McCoalroller
    7,844
    7,310
    Pennsylvania
    2018 Prius c
    Keep in mind, no Prius ever had a soft cushy ride. That went out the window in the quest for better MPG.
    Now, on a second reading it sounds like you were trying to find some aftermarket performance struts to improve the suspension beyond stock, rather than to cure a defect.
    The bad news there is that everyone who wants aftermarket struts is not looking for a soft cushy ride; that's not how they're tuned. So it's kind of a moot point that there is no aftermarket for the Prius-specific parts.
    So it's unlikely that you would have wanted those struts anyhow.
    If you think your Prius should ride better for what it is, take it for an alignment and consider new tires. Those steps really can help, but nothing in a garage is going to work miracles: if you want that soft limo ride, try a bigger car like an Avalon Hybrid.
  8. Mendel Leisk
    40,540
  9. sam spade 2
    7,035
    2,798
    2017 Prius c
    Any given vehicle has either shocks OR struts; never both on the same set of wheels.
    It's fairly typical to have struts up front and shocks on the rear.
    You can't mix and match. Replace with what it was designed for.
