Kwh, charge time, EV range
Discussion in 'Prime Plug-in Charging' started by crewdog, Dec 12, 2016.
  1. bisco
    52,801
    good point. i guess we can't fix cold.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    A cold motor will be more efficient. Cold fluids and tires will be less efficient. I'd say tires will dominate.
    52,801
    so, if you charge in a heated garage, you should be good to go? or will the tyres cool off as you drive?
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    all this EV range stuff is hurting my brain:confused:
  5. Lee Jay
    5,850
    4,036
    Tires have very little thermal mass and have tons of air flowing by them plus direct contact with the cold road.
  6. Tideland Prius
    16,673
    Just to clarify, it's the battery warmer that is included in Alaska and Canada. This comes on after the 3 days of heating and will warm up to the 31st day after the charging cable was first plugged in. The 3-day battery heater is on all vehicles.
    That's the way I interpreted the manual.
    Trollbait likes this.
  7. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    I have watched the tires on the Lexus RX450h warm/increase psi from several pounds low with the tpms light on into normal temp range, light goes off, at 65mph(I-79) with temps in the single digits. Can't recall ever hearing that a tpms light came on while driving because of really cold temps. Might be something interesting to study if we could see the tpms data and log it.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I was answering your post saying it is impossible. Now you say it is.
    Wrong. The battery heater (operating as needed for up to 3 days provided the car is plugged-in) is for all areas. The battery warming function (starting after the heating function is stopped) for additional 27 days (as long as plugged) is for Alaska and Canada only.
    We had this discussion in the past in another thread but it seems you refuse to let the facts confuse you.:eek:
  9. bisco
    52,801
    is this the same car with the warning in the owners manual, not to leave it plugged in after it's done charging, or you'll drain the 12v battery?(n)
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Could be...old brain remembers well:)
  11. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Ever heard of an intact tire that loses pressure after a drive ?
    I'm curious, so I'll check mine tomorrow. Ambient should be about 28-30F with snow showers during my 45 mile drive.
  12. bisco
    52,801
    well, something drops my m/kwh as soon as the weather starts dropping below 70. but i don't have a battery warmer.
  13. Lee Jay
    5,850
    4,036
    I did a test once. There's a particular hill I started at 40mph at the top and put the clutch in at that point. I made sure the tires were at the same pressure for each run.
    When it was 85F, I got to the bottom of the hill at 51mph. When it was 25F, I got to the bottom of the hill at 28mph. Remember I started at 40mph.
    This was only a few days apart (swings like that are common in Colorado), and I did have to inflate the tires before the run on the 25F day to get them back to the same pressure they were on the 85F day. The roads were dry on both days. In both cases I had the same starting point about 7 miles away.
    #93 Lee Jay, Jan 2, 2017
  14. bisco
    52,801
    that's uge. what do you attribute it to?
  15. Trollbait
    12,812
    Everything being cold.
  16. Lee Jay
    5,850
    4,036
    Tires.
    Rubber changes hardness and elasticity with temperature. Try bouncing a rubber ball after it has been in the freezer. It won't bounce as high, indicating it isn't returning as much energy after flexing.
    inferno and bisco like this.
  17. AKCoffee
    AKCoffee Junior Member
    46
    23
    2014 Prius v wagon
    Aerodynamics...Denser air at lower temps.
    More internal friction...Try pushing your car in N at 85f and then again at 25: big difference.
  18. bisco
    52,801
    i guess we're stuck with buying a battery big enough for winter.
  19. Lee Jay
    5,850
    4,036
    Wasn't that. I forgot to mention it but the air density was the same both days. I do wind energy research so we calculate air density constantly.
  20. inferno
    inferno Senior Member
    1,072
    405
    I've noticed the same thing going down a hill in freezing temperatures. My same drive would yield 30mph at a certain point in the winter, but in the summer it would yield 50+ and I would use my regen more and get more mpg. Factors...
