Kwh, charge time, EV range
Discussion in 'Prime Plug-in Charging' started by crewdog, Dec 12, 2016.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Yup, I'm sure
  2. priuscatprimeguy
    2,730
    2,640
    Just checked my journey s with my AAA app ICE came on January 2nd so I added up the miles from the 2nd to today and it comes to about 63 miles
  3. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Climate prep worked using heatpump I'm guessing. Did you continue to use the heatpump on the way to IHOP or ruff it? May have frosted up the evaporator and it switched to ICE heat if that was on. Evap temp needs to be 5 to 10 degrees lower than the outside temp to draw any heat adding more degrees of frost.
    EV-ish likes this.
  4. priuscatprimeguy
    2,730
    2,640
  5. Trollbait
    12,767
    I believe the low temperature limit for the heat pump is 14F. If so this sounds like the ICE came on for cabin heating.
  6. priuscatprimeguy
    2,730
    2,640
    That would make sense except when I went to IHOP the outside temperature was 12 degrees and ICE did not kick in:confused:
  7. Trollbait
    12,767
    The post I quote made it sound like it had 'warmed' up to 14F by the time you got out of there.
  8. priuscatprimeguy
    2,730
    2,640
    Actually I stated the outside temperature of 14 degrees after charging at chargepoint for about an hour
  9. Trollbait
    12,767
    Oops, I flipped the ICE on points.
    With a preheated cabin, the heat pump may have been able to maintain the temperature for the first part of the trip. Eventually, keeping the heat up in the cabin became a losing battle for it.
    Or this occurred.
    priuscatprimeguy likes this.
  10. priuscatprimeguy
    2,730
    2,640
    Yup, probably what happened is the cabin and the battery area cooled down while I was in IHOP and did not sufficiently warm back up during the 2 to 3 mile trip to the Chargepoint location and the one hour charging (since you can't heat the cabin while charging)
  11. Tideland Prius
    16,642
    Right.
    But you can also pre-heat via the Remote A/C button on your fob prior to getting into the car, right? so you can let it charge an extra 10 mins (the time limit of the pre-heat or pre-cool function)... you probably won't gain any miles (might lose a bit) since the battery is pre-heating the cabin but at least the car is off so the engine won't be on.
    priuscatprimeguy and giora like this.
  12. priuscatprimeguy
    2,730
    2,640
    ok, true, but on that same token you can turn on remote climate from your phone and not even get out of your car, the chargepoint location I was at the consumers energy office was not open till 9:00 am ( the time when I finished charging) so no where to go to warm up.:cool:
  13. Tideland Prius
    16,642
    Oh ok. I read your previous post as you couldn't pre-heat (with the smartphone) while charging.
  14. priuscatprimeguy
    2,730
    2,640
    good point. Also from the key Fob.
  15. Tideland Prius
    16,642
    Wait so I'm confused now because I mentioned the key fob early (remote A/C).
    So can you or can't you turn on the heater while the car is charging (without using climate prep) at a public charging station?
  16. priuscatprimeguy
    2,730
    2,640
    I'll have to get back to you on that one.
    Tideland Prius likes this.
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    According to the owners manual, page 509, you can.
    If the Remote Air Conditioning System is used while the charging cable is connected to the vehicle, the reduction of charge in the hybrid battery (traction battery) will be suppressed to allow you to use elec- tricity from an external power source.
    Charging will be conducted automatically after the Remote Air Condition- ing System is stopped.
  18. bisco
    52,633
    why will 'the reduction' of charge in the battery be suppressed? seems like funny wording.
  19. priuscatprimeguy
    2,730
    2,640
    You do understand that it's a losing battle when it's 8 degrees outside, charging, then heating the car up, then back to charging while car rapidly cools off, then it's back to charging, it's probably better to wait till the car has finished charging then heat up the car after you unplug the cable.
    Tideland Prius and bisco like this.
  20. Lee Jay
    5,850
    4,036
    I'm not sure what it said before it was badly translated from Japanese to English. Probably that using the climate while plugged in will reduce or even reverse battery charging.
