kWh consumption
Discussion in 'Prime Main Forum (2017-2022)' started by Nic Steussy, May 23, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Screenshot_20170527-225329.png Screenshot_20170527-225416.png Screenshot_20170527-225416.png Screenshot_20170527-225426.png Screenshot_20170527-225439.png Screenshot_20170527-225455.png
  2. priuscatprimeguy
    2,730
    2,640
    took a while to figure out why it wasn't working (it kept saying "waiting for juice plug device") so I disconnected from my Mobile Hot spot and connected to a nearby XfinityWiFi and violah! it works!:D
  3. priuscatprimeguy
    2,730
    2,640
    @bwilson4web I have had this Juice Plug for about three weeks, I worked in the beginning as you can see from my previous posts> It hasn't worked since. Got ahold of Emotorwerks and so far no response that was on the 13th of June. It connects fine but I get to the point where it says :waiting for Juice Net device" So I'm waiting.......and waiting.... this goes on for about an hour so I finally give up and return to my apartment to sulk :mad::cry::notworthy::sick:
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    @priuscatprimeguy Did you try going back to the setup.com site again?
    It takes mine about two minutes to hook up into my wifi when I use the supplied charger. So it loses that time, though I still think it tracks the kWh used accurately. I also had an issue where the Recent wouldn't remember after it went offline. For the last few days it's begun to work.
  5. bwilson4web
    16,512
    I wish I could help. My experience is their equipment works fine when it stays connected to a permanently connected, local WiFi. Your symptom suggests the device is not finding the local hotspot.
    Let me suggest going back to initial learning setup to see if once is it POWER ON, the default IP address is enabled and you can use the browser to reset the WiFi network. Understand this is pure speculation but the "waiting for Juice Net device" suggests either the WiFi connection and/or associated account on their server is broken.
    I see this link problem in the e-mail log:
    The JuiceBox Pro down at Propst is using a T-Mobile hotspot and I suspect we're seeing the box-to-server link frequently going down and up. Sometimes I suspect it is 'server maintenance' and other times, the network link.
    #25 bwilson4web, Jun 18, 2017
  6. priuscatprimeguy
    2,730
    2,640
    Several times, I always end up with the "waiting for juice net device" portion
  7. priuscatprimeguy
    2,730
    2,640
    Since I am very far away from my computer I have to resort to the app on my phone, are you suggesting I open chrome browser to the emotorwerks website?
  8. priuscatprimeguy
    2,730
    2,640
    I have done a speed test on my phone to test xfinity WiFi and get at least 8 mbps
  9. bwilson4web
    16,512
    Doing this from memory (always a mistake,) after power-on, the JuiceBox Pro has about a two minute window when it reverts to a 192.*.*.* address that we can connect to with the browser. This gives us 'console' access to configure the WiFi it is supposed to use. Once that is done, the box reaches out to the server. Then we switch to the normal operation.
    HPrimeAdvanced likes this.
  10. priuscatprimeguy
    2,730
    2,640
    I have tried to use my Samsung Galaxy S7 hotspot, but when I do I can't find the SSID on my phone when the Juice Net ask's for wifi name, what am I doing wrong?
  11. alexcue
    346
    311
    So Cal
    First get the juicenet-**** wifi. Then go to setup.com. There you tell it to find your wifi.
    priuscatprimeguy likes this.
  12. priuscatprimeguy
    2,730
    2,640
    I did that, Samsung Galaxy S7 hotspot does not show up
  13. Mendel Leisk
    42,249
    I wonder why the car can't display the charging amount? Technically difficult? Or in the same category as tachometer, coolant temp, ie: arbitrary exclusion? Maybe a request for @Prius Team.
    HPrimeAdvanced and bwilson4web like this.
  14. priuscatprimeguy
    2,730
    2,640
    It helps to follow directions lol, got my mobile hotspot to show up, but on my phone it still says waiting for juice net, but on my tablet the juice net is giving me data
    HPrimeAdvanced and alexcue like this.
  15. priuscatprimeguy
    2,730
    2,640
    Ah, fixed it, while still connected to the car I logged out of the app then logged back in and pow! App is displaying the stuff I posted earlier
  16. bwilson4web
    16,512
    We're good now?
    If you get a chance, plug it into a L2 charger. Once it is charged, enable the A/C and see the load.
  17. priuscatprimeguy
    2,730
    2,640
    Ok, it may be a week or so before I use up what I've charged today
    HPrimeAdvanced and dalcon95 like this.
  18. priuscatprimeguy
    2,730
    2,640
    darn, not following directions, AGAIN! while it was still charging (had a full charge from yesterday and L2 chargepoint is 2 miles away) The amperage went down to .5 amps then after a few minutes it kicked in to 15 amps then kicked out after about a minute back to .5 amps. So, the correct way is wait till car has finished charging then kick in remote A/C from fob and check load, right? @bwilson4web
  19. priuscatprimeguy
    2,730
    2,640
    Ok, followed directions this time,lol, since the only L2 charger I have access to is a Charge Point station results in the Charge Point shutting off after the car finishes it's charging and my stats indicate 0 volts, 0 amps, and 0 KWH's Interestingly though I turned on A/C remotely from the fob ran it for a couple of minutes, tried to restart my session with Charge Point, that failed because the car is still fully charged. Sorry to let you down @bwilson4web :sick::cry:
    dalcon95 likes this.
  20. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It worked fine for me.
    Added exactly 4.0 kWh to restore capacity to 100%, waited, then started remote A/C via the app.
    After that A/C finished, the ChargePoint charger automatically resumed... which you can see all in the same session.
    0.38 kWh is what was added back afterward.
    #40 john1701a, Jun 19, 2017
