kWh consumption
Discussion in 'Prime Main Forum (2017-2022)' started by Nic Steussy, May 23, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    @john1701a I don't know what kind of Charge Point you're using but the one near my house when the car has finished charging the Charge Point station resets and says "charger ready, tap card to start" I went back to the site again to perform the test you guys are doing. I charged the car, waited till it was finished, then went to remote climate turned on climate for max cool, waited the ten minutes, went back to the charge point station terminal where it said "tap card to start" which I did, green light on car lit momentarily then went off, so then I went back to remote climate and started another session (of which it reminded me to lock the doors) started another session this time successfully, Tapped my charge point card and the car started charging at .4 amps probably because I started a new remote climate session , after that ten minutes was up the amperage jumped up to 15.2 amps. charging time was 21 minutes Energy (kwh) 0.39
  2. bwilson4web
    16,533
    Here is the 2017 Prime Prime charging followed by a fob activated A/C:
    I'm not sure if a second application of the "A/C" button turns if off. I remember turning it on; not sure, I did it a second time, and; when I got the car, it was no running so I used the button a third time. Regardless, the definitely used the 16A rate for a couple of minutes and then tapered off.
    I'll be doing more tests this summer to get an idea of how long it runs under the worst case. Also, I wonder if it is just a single cool-down or does it sustain the temperature for some finite period of time.
  3. priuscatprimeguy
    2,730
    2,640
    Here is the 2017 Prime charging but the first one is the charging before I applied A/C from remote climate and the second pic is remote climate activated. Priuscatprime regular session.JPG Priuscatprime A C session.JPG
    bwilson4web likes this.
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    What Charger are you using the Juiceplug on? Or is it just a a Juicebox with Juicenet built in?
  5. priuscatprimeguy
    2,730
    2,640
    Lol, I have a 120 VAC outlet next to my parking spot at my apartment complex. The post earlier was when I was at Consumers Energy's Charge Point station. No, No JuiceBox just a regular Juice Net (Juice Plug):D
    alexcue likes this.
  6. priuscatprimeguy
    2,730
    2,640
    I'm upstairs on the 14 th floor while my car is charging, should be done by 4:00 PM or so........ charging stats 6-21-2017.JPG
  7. priuscatprimeguy
    2,730
    2,640
  8. bwilson4web
    16,533
    During the day, the 110-120VAC outlet will show variations in voltage. I suspect this accounts for the different charge rates. One caution, if the A/C comes on to manage the battery pack temperature its load will be embedded in the data.
    We've now both seen that either L1 or L2, the Prime will initially max the current at 16A if the A/C is activated. Just we don't have a good way to see if that is going on ... well there is a way but even I don't like it:
    • Use a J1772 extension to run the JuicePlug into the cabin of the car. Then monitor the cabin temperature ... See I knew no one would like this!
    • Get a time-stamped, temperature recorder and monitor the cabin temperature during a charge cycle. This one I like.
    #48 bwilson4web, Jun 21, 2017
    priuscatprimeguy likes this.
  9. priuscatprimeguy
    2,730
    2,640
    voltage went down to 109 volts graph of lower voltage juice net device.JPG voltage and kwh changes Juice Net device.JPG
  10. alexcue
    346
    311
    So Cal
    It's interesting how your Max charging rate is lower than mine. Mine is at 1.40kW to 1.37kW. yours also shows much more variance in the peak than mine. by looking at my longest time @ 120V (usually shows 118 to 119V) my longest time to date is 5:07 charging time and total of 6.78kWh from an empty EV range.
  11. priuscatprimeguy
    2,730
    2,640
    The wiring to the outlet has a long way to go from the circuit box and it's probably 14 guage
  12. alexcue
    346
    311
    So Cal
    That could be it! Mine is right underneath the meter (panel) maybe 1.5ft of wiring to it.
  13. priuscatprimeguy
    2,730
    2,640
  14. priuscatprimeguy
    2,730
    2,640
    See the red truck? The garage next to the truck is where the meter and circuit box are, I took the picture about three feet away from my car, update, I guess you can't see the red truck, lol. it's as far as you can see in the upper 2/3 of the picture by the red no parking sign
    #54 priuscatprimeguy, Jun 21, 2017
  15. priuscatprimeguy
    2,730
    2,640
    ok, finished, here's the results total KWH for 6-21-2017.JPG Screenshot_20170621-152347.png Screenshot_20170621-152358.png Screenshot_20170621-152409.png Screenshot_20170621-152415.png
  16. bwilson4web
    16,533
    Did the circuit breaker trip?
    The reason I ask is a circuit breaker has a non-linear temperature response. As it gets hotter, its resistance increases. But if not enough to trip, it could go into a slow oscillation like we see at the charging rate.
  17. priuscatprimeguy
    2,730
    2,640
    Are you referring to me? If yes, then, no the circuit breaker did not trip.
  18. priuscatprimeguy
    2,730
    2,640
    I got back from my 250 mile round trip, so, "dead" battery. I had problems with the Juice Plug ( forgot to open app when I started session, so came back downstairs from 14th floor to remove Juice Plug, wait for all led's to shut off, then went to my wi fi connection and connected Juice Plug Wi Fi, back on line after about 10-12 minutes of charging without Juice plug data) Here's my results. Full Charge from dead battery 6-24-2017.JPG Screenshot_20170624-230456.png Screenshot_20170624-230440.png Screenshot_20170624-230429.png
  19. priuscatprimeguy
    2,730
    2,640
    Juice Plug says I have 18 miles added. Car say's I have 30.6 Miles EV:eek:
  20. alexcue
    346
    311
    So Cal
    You can adjust that in the settings. :p
    priuscatprimeguy and bwilson4web like this.
