kWH readings upon charging
Discussion in 'Prime Plug-in Charging' started by Tim R, Jan 18, 2017.
  1. Tim R
    Tim R Member
    St. Louis, MO
    When recharging my Prime, I regularly get between 5 and 6 kWH for a full charge, when I'm at 0 miles or near 0 miles of EV range. But its an 8.8 kWH battery. Anyone know why?
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Battery longevity is achieved by never operating at extremes.
    For Prius PHV, that means "full" is actually 85% and "empty" is 23% for usable EV capacity.
    I'm not sure what the range is for Prime, since my delivery wait is not over yet...
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    As John said, 0 miles is not zero State of Charge and full charge is not 100% SOC, there are buffers both sides.
    If we take EPA official scores we can have an idea of the usable portion of the battery charge: on the test the prime moved 25 miles EV while consuming (from wall) 25.3 kWh per 100 miles (EPA rounded it to 25), so, 25*25.3/100=~6.3 kWh from the wall.
    There are charging losses, actual charge into the battery will depend on those losses, example: if charging losses are 15% then 6.3*0.85=~5.3 kWh accumulated in the battery.
  4. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    This is exactly right, but it also implies that the Prime average about 212 Wh/mile over the 5 cycle EPA test.
    I know that the Prime is an exercise in efficiency, but I have trouble accepting it is *that* efficient. Even 225 Wh/mile is amazing.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    If the 212 Wh/mile you mention is 'from battery' after 15% charging losses, please bear in mind that Toyota claimed they have improved charging efficiency with the Prime (to 90%?) so it could be 0.253*0.9=0.228 Wh/mile from battery in the EPA 5 cycle test.
    EV-ish likes this.
  6. Trollbait
    11,544
    The Prime is also a hybrid, so it needs to also save charge in the battery for hybrid mode in addition to having buffers for longevity.
    Published EPA ratings are from the wall, so include charging losses.
  7. EV-ish
    602
    278
    SW US
    In the case of the EPA -- assumed charging losses
    Trollbait likes this.
  8. Trollbait
    11,544
    Yep. Do you happen to know if they assume worse case?
  9. EV-ish
    602
    278
    SW US
    I've been told that they use a generic L2 charger. I vaguely recall 13% charging losses. Sorry I cannot be more certain.
    #9 EV-ish, Jan 19, 2017
  10. Trollbait
    11,544
    L2 would be about best case. L1 is generally worse in terms of charging efficiency.
