Lack of check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Darcy851, Jun 14, 2026.
  1. Darcy851
    Darcy851 Junior Member
    United States
    I've always passed California smog with no issues, but this time failed because my check engine light doesn't illuminate in maintenance mode. Looking back, I can't remember whether I have ever seen my check engine light turn on. I bought my car from a questionable seller 5 years ago, and I wouldn't be surprised if they somehow tampered with the check engine light. Does anyone have suggestions about where I should check to see if they disconnected it? I know that in the Gen 3s the check engine light is an LED, so they couldn't have just unscrewed a bulb. Maybe they snipped a wire? Does the check engine light plug into the ECUs behind the glove box?
    Thank you for any advice.
  2. Mendel Leisk
    42,369
    I’ve had ours in maintenance mode a few times, can’t recall if it lit the check engine light. Was the inspection at your usual place, seems kind of sketchy.
    Google AI mentions specific lights that WILL come on, but not CEL:
    https://share.google/aimode/KiyBXplKm9O08RDlZ
    if I’m ambitious I might test it, but currently have some woodwork project headaches on the go. :)
    Darcy851 likes this.
  3. ChapmanF
    19,053
    Darcy851 and Brian1954 like this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,983
    Texas Hill Country
    I doubt the emissions inspector put it in the Prius specific maintenance mode.
    Even if he did, the check engine light is off in that mode.
    Ignition On, two presses without the brake, illuminates the check engine light among others.
    #4 rjparker, Jun 14, 2026
    CR94 and Brian1954 like this.
