Lane keep assist annoying beep
Discussion in 'Prime Technical Discussion' started by EazyPeazy, Nov 16, 2018.
  1. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    6 month prime owner and still enjoying car for the most part. However this lane keep assist beeping sound is really getting to me. I checked everywhere and it appears I can’t turn it off. I know I’m highway driving it is very useful when drifting unknowingly outside of lane, but in regular day to day driving, I find it unnecessarily annoying. Anyone know a workaround?
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Middle steering wheel button on right side. Right of heated steering wheel left if dynamic cruise control spacing.
    It’s sticky so you need to turn it on yourself.
    Or
    Use turn signals when changing lanes.
    Or
    Actually stay in your lane?
    pakitt and Pulse07 like this.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    You can adjust detection sensitivity too.
  4. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    I want it turned off. I know about the sensitivity. Thanks.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    On my 2016, there is an on/off button on the right side of the steering wheel next to the cruise control adjustment. This pic is not correct, but shows the arrangement of the buttons. Maybe later models/Primes don't have this switch...
      File size:
      42 KB
  6. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Yes. We have it on the prime. But I must be missing something. When I just press it nothing happens. When I deep press and hold a pop up on the MID shows LKA turned on.
  7. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s a toggle. Press once off. Press again on. There is an indicator light on the right lower dash that toggles on and off as well.
    citiprius and EazyPeazy like this.
  8. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    The prime has a button on the right side of the steering wheel with a car veering off the lane press it and the M.I.D should say that its off. If that doesn't work the dealer shouldn't charge u to fix it.
  9. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    For me, it almost never goes off unless I really am creeping over lanes. The only reason I can think of for why it might beep a lot at you would be if you’re not using turn signals...? (Not criticizing; just suggesting a possible explanation.)
    #9 mr88cet, Nov 17, 2018
    SteveMucc likes this.
  10. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Thanks. It does work now. Solves the headaches of that constant beeping.
    lbligh likes this.
  11. chenderson2
    chenderson2 Member
    94
    57
    Houston
    If driving on reasonable roads, I wouldn't mind it. However, driving in Houston it drives you nuts. Our lane markers look more like spaghetti than lane markers. This is due to all the construction going on here. They redraw the lane markers, but don't mark out the old ones. This, the lane change warning is always going off.
    Brings to mind a question I have: Do those self driving cars use lane markers to do their navigation? If so, self driving cars would never work here.
    EazyPeazy and fuzzy1 like this.
  12. mr88cet
    2,313
    1,335
    Austin, TX
    Having recently taken a Thanksgiving trip to Houston (and having grown up there), I saw one especially-bad case of that myself, although most lane markings were pretty clear. All in all, it doesn’t seem like I got beeped at a lot during that trip. Then again, I didn’t take a really careful tally of times when it may have “thrown up its hands,” and turned off the LDA system.
    As for self-driving cars, two things: There’s a lot of different kinds of self-driving technologies, each with its own advantages and disadvantages. Generally speaking though, damaged or otherwise unclear markings are among the biggest challenges for autonomous-vehicle designers.
    iPad ? Pro
  13. fuzzy1
    10,713
    Even here, I see places with three contradictory sets of lane markings. One only is current, and probably best visible in dry daylight. But in construction zones. the previous two will be painted over but still visible from glossy wet reflections, sometimes even the most visible when facing into a low sun after a rain burst. Even after construction is complete, some of these obsolete markings take a very long time to wear away. The ones removed by pavement grinding can remain detectable for years. And the concrete pad lines remaining after old lanes are realigned, will never go away.
    In heavy traffic, this can be hard enough for humans to figure out, and not all of them get it right even when paying full attention.
  14. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Yeah. I feel your pain. Here in upstate New York there are all kinds of lane markings that are either worn away or glaringly bright. Am glad I can turn it off now. It’s funny though how it can sometimes read faded lane markings better than crisp, recently painted ones.
  15. fuzzy1
    10,713
    I'm not at all surprised. In certain light and weather conditions, the old (and now incorrect) marks sometimes show up better to my eyes too.
  16. PearlBlizzard
    PearlBlizzard Member
    75
    31
    So Cal
    Sadly, there is little logic in the lane keeping assist system. It fails to recognize the location of adjacent cars to keep a wider birth when they are close to the lane edges (still staying in your lane, of course). It also fails to prioritize lane position by the lane you are traveling. For example, in a 2 lane road it should hold you close to the shoulder side away from the oncoming cars. Driving in the far left lane of a divided highway it should hold you closer to the inner shoulder line. These can all be done simply with programming, and greatly increase safety. Instead, being a defensive driver, you are constantly fighting the lane assist. Another fail by Toyota engineers. Hope they fix these flaws in future generations.
  17. fuzzy1
    10,713
    To me, that sounds more like consumer expectations getting ahead of current product reality. These products are still at the Level 2 stage, far short of self driving cars. I don't believe the programming is as simple as some believe.
    lbligh likes this.
  18. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    My Prime has the beeping. My other car has the steering wheel shake. I like that a lot more. I agree mine rarely goes off. Usually when I am avoiding a pot hole. Using the turn signals help.
    Pulse07 likes this.
  19. paul518
    paul518 New Member
    albany ny
    For me the question is not turning off Lane Keep Assist, but it is USING Lane Keep Assist without the annoying lane departure beep.
    Can you use the system without the beep?
    Salamander_King likes this.
  20. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    I don't think so, but that would be nice. I had LKA turned off on my previous PPs with TSS1.0. But with my new 2021, TSS2.0 has improved the LKA with a much better steering correction response. Yeah, the beep is annoying enough to keep it turned off, but if I can use it without the beep... Humm, that may be good.
