Lane keep assist?
Discussion in 'Gen 4 Prius Technical Discussion' started by Runningkiya, Sep 7, 2016.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Mine doesn't work at night, often fails to detect the lane lines/Botts dots, and sometimes gives false alarms. Rarely do I ever feel the steering assist; which is so slight it's pretty useless. In summary, I give LDA on my Prime an "F" rating. Maybe something is wrong with it or maybe that's the way it's supposed to be. When I take it in for the 5000 mile service, I'll complain about it.
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I played around with all the settings the other day and changed the sensitivity of LDA from Standard to High. With LDA selected then crossing the white line on the road caused the steering to nudge me back as well as beeping. Because the sensor is optical the camera (behind the rear view mirror) must be able to see the lane markings distinctly. Poor markings may not be detected and using the normal setting has minimal steering correction - just the warning as far as I know.
    pilotgrrl likes this.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Really? Mine works best at night because shadows from trees and other cars during the day often cause the camera to lost track of lanes. I have more confidence in the system at night than during the day.
    alanclarkeau likes this.
  4. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I was surprised how much i like it.
    pilotgrrl, RCO and alanclarkeau like this.
  5. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Speed related. 45 is not optimum. 55 and up it works great.
    However, quality of lines makes a big difference. Not sure why as sometimes faded lines work better.
    On a long trip between surgeries and use a towel to increase the lumbar action.
    RCO likes this.
  6. Michael Ge
    Michael Ge New Member
    27
    25
    I'd like to propose we all sign a petition to Toyota that they make the steering assist work like it does on the other Toyota models. Anyone want to join me?
    krmcg likes this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Bit late now - the design won't change till at least the mid-cycle update or more likely next model. It certainly won't affect cars already sold - TOYOTA doesn't work like that - TESLA is about the only one.
    Our road networks aren't yet marked well enough for it to be totally consistent, but it certainly works as designed.
    pilotgrrl and RCO like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I turned mine off, it was so annoying driving home from the pub :whistle:;)
    Sommer86, RCO, krmcg and 2 others like this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yeah, that and the coffee cup together! :confused:
    kithmo and Prodigyplace like this.
  10. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I like the coffee cup, it's very Japanese. I can only imagine what an American car would say before it pulled off the road and refused to start.
    kithmo and RCO like this.
  11. Prodigyplace
    12,713
    11,848
    Central Virginia
    I believe @alanclarkeau here was looking for the Qi coffee maker option. :LOL:o_O
  12. Mendel Leisk
    42,347
    I'm thinking similarly. I intentionally cut over some "lane lines", say an oncoming left turn lane that's jutting out: if there's no oncoming traffic I'm less inclined to slavishly follow the zigs and zags, will intentionally clip it, and wouldn't want a "nanny" nudging me back, beeping. Same thing with winding roads out of town, with clear visibility and no oncoming traffic, again: I'll sometimes intentionally go over the line a bit.
    krmcg likes this.
  13. Prodigyplace
    12,713
    11,848
    Central Virginia
    I believe it does not warn if you are using your turn signal.
    kithmo, krmcg and RCO like this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    True but you'd not use that to just cut the corners with no other traffic about.
    krmcg, Prodigyplace and Mendel Leisk like this.
  15. Mendel Leisk
    42,347
    Yeah, following my "racing line"... :whistle:
    RCO and Prodigyplace like this.
  16. Tideland Prius
    16,680
    It won't say anything :whistle:
    You can turn it off. Only turn it on if you're going to be driving on the highway.
    RCO, Prodigyplace and Mendel Leisk like this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I don't think it really works like that. It's intended for use on highways, i.e. straight or slight curves, it scans the road ahead. On a corner or sharp bend it can't see that you're cutting the corner, on a longer curve it maybe could as it takes into account the amount of steering (yaw rate) you are applying to determine if it will warn you.
    Mendel Leisk and RCO like this.
  18. alanclarkeau
    7,045
    7,593
    I flick it off on mountain roads, keep it on the rest of the time.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    @kithmo - It really does. It's when the camera detects you're crossing the white line without prior signalling that is the trigger. If the line is not clear or not present, then it won't!
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    But if the curve is tight then the camera won't see the line, even if the line is clear, because it's outside the camera's field of vision.
    RCO likes this.
