Lane keep assist?
Discussion in 'Gen 4 Prius Technical Discussion' started by Runningkiya, Sep 7, 2016.
  1. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes so was I. To quote the UK manual, page 112: "When the brakes are applied suddenly, the emergency flashers automatically flash to alert the vehicle behind"
    It's called the Emergency Brake Signal.
    alanclarkeau, RCO and Prodigyplace like this.
  2. Tideland Prius
    16,680
    Lane Keep Assist was an active system that monitored the white or yellow lane lines to keep the vehicle centred in the lane. This meant that there would've been near-constant movement of the steering wheel (like Tesla's autopilot) as the system made adjustments to keep the Prius centred. If you started drifting towards the edge, it will pull you back but it's not a perfect system and you could end up bouncing within your lane. It can handle light corners but not at 100% of the time.
    In short, it was a more active, aggressive system than LDA w/ SA (Which is a passive system).
    Yeah the Prius does that in Europe at least. I think European-spec cars have had this feature for a while.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  4. Fester
    Fester Active Member
    201
    198
    Ohio
    If I had my druthers, for me personally I'd rather have a more active steering lane control, but sorry Toyota, I'm not going to buy a new one in the future just to get that option, even though I'm reasonably sure it could be implemented by new firmware (and yes I know they won't...).
  5. Prodigyplace
    12,713
    11,848
    Central Virginia
    Have you had to test then out? :eek:
    Our flashers flash at the same rate as turning signals, just both sides at once.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Fortunately, I never had to test them for real, but ours flash like yours do. Walks away buttoning raincoat....
    kithmo and Prodigyplace like this.
  7. Prodigyplace
    12,713
    11,848
    Central Virginia
    The video from @kithmo shows the lights flashing more rapidly that usual.
    kithmo and alanclarkeau like this.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It looks the same with Australia - I just found that out:
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You're right again. I think I was referring to the hazard flashers and not the video. As that was a CGI production, I assumed the speeds and timings were not to scale.
    syncro87, kithmo and Prodigyplace like this.
