Largest or most unusual Load Carried in Your Prius
Discussion in 'Gen 2 Prius Main Forum' started by jmccord, Aug 2, 2006.
  1. booger
    booger New Member
    28
    Hugo, MN
    We'll see if I can fit my hunting stuff and a dead deer in there if I shoot one this fall. How funny would that look?
  2. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    I've not carried anything unusual yet in the Prius, although I did once carry a full-size MIG welder in the back. The suspension was complaining very badly.
    But how about this for strange things in something a lot smaller.
    That was before I got my Prius and was still using the electric Bubble car that is the City El.
    It was a washing line for our new home...
  3. redhandeddenial
    138
    harrisonburg,va
    "mike there is no way you will fit more than one of these in there" jon says
    i say " give me all 5 plus your spare" :eek:
  4. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    8' ladder with the hatch closed. The top rested on the dash, though. It would've become messy had the airbag deployed.
  5. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    I was going to pick up a 52" LCD TV from Best Buy. I looked online to get the dimensions of the shipping box and found it would fit. Cold not have been 1" longer, higher or wider. The 2 guys that wheeled it out laughed as I pulled my Prius around. They were scratching their heads as I pulled away with the hatch closed even.:eek:
  6. TravelBliss
    TravelBliss It's worth the wait !!!
    158
    Sunny Prius heaven :)
    You're KIDDING me, right?
    I wish you had photo of that still in the car....wow!!!! ;)
  7. jammin012
    jammin012 The man behind The Man
    510
    Cali
    OK, what support do I need to install in order to transport a "92 Firebird 305 TBI engine w/o trany? I figure the weight would destroy the deck lid so I'm thinking of something on top of the spare tire or removing the spare completely.
    Yes, before, during and after pictures will be sent when mission complete.
  8. Wildkow
    Wildkow New Member
    5,270
    37
    36
    I got these two 2005 Volvo S60 power seats into the back of my Prius with room to spare. The guys at the junkyard couldn't believe it when I told them I brought my Prius and were still shaking their heads when I drove off.
    Wildkow
    Try a half sheet of 1/2 inch plywood in the back that should help. If'n your not in a big hurry wait till I get back and we can take my Highlander over to get it.
  9. jammin012
    510
    Cali
    no hurries. I just need to get it to Reno before the snow season.
    I have plenty of time for R&D.
    I am worried about roof clearance as I'll need room for the hoist to get it in and out. I'm pretty sure I can limit it to 5" over intake height which would put me right above the TBI. That's why I'm thinking of using the spare storage space. Preliminary measurements indicate I might be able to get the oil pan in before the hoist hits anything.
  10. berinker
    berinker New Member
    43
    Santa Barbara, CA
    Well, the best test is to haul ROCK!!!
    I used to go up on the mountain and haul down
    shale in my little Geo Metro. The best it could haul
    in it's bucket-like rear end covered in plastic was about 12
    buckets at 45 lbs each which is a quarter of a ton and it was
    pretty wobbly coming down. I got a 2004 Prius with 'no bucket'
    but I recently had a 67" TV delivered and the huge box it came in
    6 feet long and 3 feet wide fit perfectly in the back of the Prius after
    it was cut down to about 2 feet high. I went up on the mountain and
    filled the box up with 18 buckets of shale and there was easily room for
    probably 3 or 4 buckets more. That was 800 lbs (over 3/4 of a ton)
    and the Prius carried it like it was hardly even there and no wobbling. When it rains again (to cut down on the dust) I will probably go
    up and try for 1/2 of a ton. If the box was 4 feet wide I could
    probably even beat that. What a work truck!!!!
  11. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I put my 46" LCD TV in the Prius without too much trouble. Wouldn't fit in the Honda Accord, because it has a narrower gap when you fold the seats down.
    I've also put in 3 2x10's (lumber) that were cut to 100" (8'4", 254cm) with about 1" to spare (not touching the dashboard, hatch closed).
    Put in old bluebird boxes on poles, but I didn't measure them (along with my hybrid bicycle). Not your typical item however. The bicycle has 27" road wheels but mountain bike style wide handlebars, it just barely fits in the back (seats down) without having to go to lengths like taking off the front wheel. I've got a technique down for putting it in and taking it out smoothly.
    I'd be pretty cautious about a 1/2 ton of rock. The manual says 810 lbs (365kg) max, including people (like 4 Americans w/o luggage). At least go very slow on the bumps. For this, I'm sure you put your tire pressure above the doorframe recommendation.
  12. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    800 lbs is less than 1/2 a ton. Still incredibly impressive, but not quite a 1/2 ton.
    [2000 lbs is a ton. 1000 lbs is half a ton. 800 lbs is 2/5 of a ton]
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I was able to fit a chair from Crates & Barrel and close the hatch.
    Another pic showing the extra room left with the back seats folded down.
      File size:
      117.6 KB
      1,281
      File size:
      101.3 KB
      849
  14. berinker
    berinker New Member
    43
    Santa Barbara, CA
    Sorry. Yes, I got my fractions wrong
    but you know what I meant. I had extra
    air in the tires and there were no bumps
    on the 10 mile downhill trip. Driving it
    there was no sense at all of the load
    in the back where as the Metro
    wanted to swap ends.
    Bud
  15. Turbogizzmo
    Turbogizzmo New Member
    75
    Colorado
    10 computers, could have fit more but thats all they had..../
  16. Artis
    Artis Junior Member
    Alabama
    How about a plane?
    Well, it was radio controlled with 6 foot wingspan and all the supporting equipment including tools, fuel, pumps, starter, etc. This included 3 adult men as well.
    Anyone in that hobby knows those planes are fragile. Mine arrived fine and it was the cheapest trip to the airfield I've taken.
  17. pdoege
    pdoege New Member
    Orlando, FL
    Scuba tanks!
    About 600lbs of them.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Well, I took some photos with the 52" Samsung Series 7 LCD in my Prius. The width barely fit. At first, I could not get it in because of the black cargo net clips were in the way. I had to push it in from above those clips.
    Samsung LN52A750 Package size (WXHXD): 56.7 x 39.0 x 17.3 in.
  19. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    A 50-gallon gas water heater. I know it shouldn't be transported horizontally but that's the risk I take. It works just fine.
  20. nooaah
    nooaah New Member
    380
    Philadelphia
    About 300 pounds worth of boxes and a desk the other week when I moved. I still managed 44mpg haha.
