Last fuel bar to empty
Discussion in 'Prius v Main Forum' started by ImeanGreen, May 6, 2013.
  1. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Does your v make a beep when it gets to the last PIP and does the last bar blink when it gets to 20 or less miles to empty? When I have 25 or less miles left, my v does not make a warning beep nor does the last bar blink like the regular prius. Is this normal? Checked the manual but could not find anything about it.
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Got the last bar to extinguish and orange low fuel light to illuminate with 20 miles range. Filled up at 4 miles range.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I usually see the low fuel light of I get within 11 miles of 'empty'. I actually have about 2 gallons at that point, but that suits me fine.
  4. ImeanGreen
    547
    73
    Somewhere out there
    I had mine at 15 miles left but got no warning light. So I thought that was strange since I use my regular prius for work and makes a beep and the last bar flashes. I thought there was something wrong with the fuel gauge. So Jimbo, it has to get close to 10 miles to empty before the fuel warning light illuminates. No audible warning sound? I'll try to get to 10 miles to zero before refueling next time.
  5. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    My fuel light comes on with a single beep and comes on at 1.8 gal remaining according to my scangauge. I have verified the scanguge againts actuall fillups and the scangauge seems accurate.
  6. mikefocke
    4,079
    1,862
    Sanford, NC
    In many cars, you burn out the fuel pump running the gas tank dry because the fuel actually helps cool the pump which is inside the tank. Not an experiment I'd want to try.
    GregC1979 likes this.
  7. 13PV
    13PV Junior Member
    82
    2013 Prius v wagon
    x2. i agree.
  8. bisco
    52,855
    low fuel light is a nice feature, i hope they start adding them across the board.
  9. Air_Boss
    4,259
    1,197
    New Yawk
    That's why the warning goes off with from 1.5 to 2 gallons left in the tank.
    skwcrj likes this.
  10. fuzzy1
    10,707
    So 0.0 on your ScanGauge does represent the real bottom of the tank on the 'v'?
    On my Liftback, it does not. It gets stuck at 0.7 gallon, never reading lower. But if it did display lower, its 'zero' appears to be offset from the real empty point of the tank. I.e., when I run it very low, the ScanGauge FLV reading plus the actual refill amount add up to less than 11.9 gallons.
    Despite the offset, I still find this a useful indicator.
  11. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Running the tank DRY is very bad for much bigger reasons!
  12. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Maybe...
    Definitely not something I want to experience for myself. But, it does appear to be accurate.
  13. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    So, this is not on the other models?
  14. ImeanGreen
    547
    73
    Somewhere out there
    Correct. The regular prius will not have the orange gas pump icon when it gets to the last bar but you will hear an audible beep and the last fuel bar blinking.
  15. bisco
    52,855
    the blinking fuel bar just doesn't catch your eye like a warning light.
  16. 2013-Prius v
    2013-Prius v 2013 Prius v 5
    198
    39
    Orange County, CA
    2013 Prius v wagon
    Just confirming; Prius v has orange blinking icon for low fuel warning?
    iPhone ?
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    An orange gas pump shaped icon lights up, but does not blink, to the left of E, at about 11 miles before Toyota's best guess of your range goes to 0.
    skwcrj likes this.
  18. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    Not in any new cars. You run out of fuel and you are fine. You add fuel and your car is no different. Now, if you do this on a regular basis, it can turn into an issue, but running out once isn't going to hurt anything. I think most people who are passionate about great gas mileage are all about testing limits, and like my Dad, will test the boundaries of the capacity of their tank at least once. :) I know that many argue the whole debris thing for the tank, but most people test their fuel tanks when the car is new, therefore the amount of debris in the tank is probably non-existent.
    I would imagine most people learn enough after the first time they run out of fuel to not want to go through the process again. ;)
    skwcrj and Offline like this.
  19. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    Excellent reply! It is amazing that people continue to regurgitate horror stories from the distant past.
    skwcrj likes this.
  20. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
    Well stated
    iPhone ?
