Latest oil test results
Discussion in 'Gen 4 Prius Technical Discussion' started by ETP, Aug 2, 2017.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    For me, it depends on the car - with a near new car under warranty, I get it done at the dealer.
    Next 3 or 4 yrs, get a logbook service done, but not necessarily at the dealer, so the book can be stamped.
    After that, I start doing my own servicing, and write in the book, keeping copies of receipts for filters, oil etc.
    When they get to 15-20+ years old, the "look at the colour of the oil" test is a good one, as in an older car this test often gets the service done sooner as it gets dirtier quicker - but in reality the car isn't worth much anyway so it's not as critical, nor will it void warranty.
    RCO likes this.
  2. Trollbait
    12,832
    That is more than what our Sable gets, and it likely sees more miles a year than your Prius. It's just an oil and filter change once a year.
    Their recommendation is likely conservative. Used oil analysis can let you determine what the actual change interval for the car, under your driving conditions, should be. This would lead to less oil used, but the costs for for the tests are too much to make the effort worthwhile for most people.
    An oil life monitoring system like GM uses is a big step forward over simply going by time and miles driven. They monitor things like temperatures and engine speeds as a proxy for determining how much stress and wear the oil is seeing.
    Keeping receipts for the oil and filters is good enough for warranty claims.
    RCO and Mendel Leisk like this.
  3. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Exactly!
    Bisco, what you drinking lately?
    Damn cholesterol pills I can't drink anything when I take them.
    #23 ETP, Aug 5, 2017
  4. ETP
    2,806
    1,170
    Auburdale FL
    More like this,
    Play the song 11:55 - Helpless
    #24 ETP, Aug 5, 2017
  5. ETP
    2,806
    1,170
    Auburdale FL
    Might be better off without a filter if they come apart inside the canister. Luck of the draw.
  6. bisco
    52,888
    i'm on atorvistatin, no alcohol restriction. i'll drink hair tonic, if that's all there is.
    goldfinger, pilotgrrl and tucatz like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Aaah yes, hair of the dog!
  8. ETP
    2,806
    1,170
    Auburdale FL
    That is the one I got sore muscles with and had to get off it.
    Sometimes I drink wine for 10 days and go off the statins then back on the wagon for a month.
  9. bisco
    52,888
    yep, me too. doc cut it to every other day, and it's much better. cholesterol in the low 200's. good cholesterol is high though, and he says that's good enough.
    of course, if i lost twenty pounds, that might solve the puzzle.
    ETP and RCO like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's very easy to do here in Eng£and. :(
    Raytheeagle, bisco and Prodigyplace like this.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    You easily spend more than that on a Prius. :D
    Raytheeagle and RCO like this.
  12. bisco
    52,888
    not to mention quid.:cool:
    ETP, RCO and Prodigyplace like this.
  13. alanclarkeau
    7,045
    7,593
    Statins - that'll do it - fuzzy head and joint pain too - which doesn't go away completely after they've done their damage.
    ETP likes this.
  14. ETP
    2,806
    1,170
    Auburdale FL
    Need a ring job, complete bore out, and a flush.
    Never had a filter.
    #34 ETP, Aug 9, 2017
  15. jj3
    jj3 Junior Member
    Four Touring
    My father tested a bunch of oils in their hot/cold cycle machine about 20 years ago. He placed about a 1" puddle of Mobil1, and the other "big players" like valvoline, castrol, ect. on a cookie sheet.
    They ran it up to 400F, let it sit for a minute, pulled the tray out and tipped it up... The Mobil1 ran down, the rest were carbon sludge.
    They got a new sheet setup, and took it down to -30F, let it sit for a minute, pulled it out and tipped it up... The Mobil1 ran down, the rest were frozen solid.
    We had a 1982 dodge colt that had Mobil1 since the first oil change, the car's shift lever (manual) rusted through the floorboards so it didn't make it past 140k miles. I pulled the valve cover off, and it had a coat of oil all over everything and zero sludge.
    My 2006 Avalon had the same treatment, with the same results at 215k miles (Till I had an unscheduled meeting with a deer the other day). Nice and clean under the valve covers, and had zero sludge. The engine drove like new, in my mind it was barely broken in... and I had hoped it would have gotten me to a half million miles. I was changing oil/filter at 10k intervals.
    Other cars I've owned and didn't run Mobile1 all had sludge buildup in the valve covers, though Castrol GTX seemed a touch better in that regard. I've tried the synthetic blends with similar sludge buildup inside the valve covers as well, just not quite as bad as the Valvolines/Quaker States/Etc.
    That's been enough evidence for me to spend the extra bucks at the oil changes and use Mobil1.
    RCO and ETP like this.
  16. ETP
    2,806
    1,170
    Auburdale FL
    Great info for everyone to ponder.
    I think the jury has voted that synthetic is best for any engine. But the jury is still out on what viscosity is best for longevity.
    IMHO, I really don't know.:LOL:
    RCO likes this.
  17. ETP
    2,806
    1,170
    Auburdale FL
    Trying a vegan diet to see if it can get me off these stupid drugs.
    Odd thing about honey is I can't find any reason not to use it other than vegans says it tortures bees:LOL:
    They don't complain about torturing those poor maple trees.:LOL:
    I will miss the 2" thick steak pink in the center and a nap afterwards.
    #37 ETP, Aug 21, 2017
    alanclarkeau, bisco and RCO like this.
  18. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Whale oil. Better than dino, better than synthetic.
    ETP likes this.
  19. ETP
    2,806
    1,170
    Auburdale FL
    Wonder what FFs taste like cooked in WO.
    goldfinger likes this.
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not exactly fishy, but better than if they're cooked in synthetic. :ROFLMAO:
    ETP likes this.
