Latest on HID headlight aim problems
Discussion in 'Gen 2 Prius Main Forum' started by rlcarr, Oct 17, 2005.
  1. rlcarr
    rlcarr New Member
    36
    Massachusetts
    We've been having problems with our headlight aim for almost ten
    months (2004 BC).
    The first thing that happened is one night the lights were aiming
    insanely low. We brought it in to the dealer and they totally blew us
    off, so we went to a different dealer.
    That dealer admitted there was a problem but (I think) only "fixed" it
    by changing the mechanical aim point (upwards), because a couple of
    weeks after the "fix", the headlights stated pointing way high
    (i.e. non-highbeams were much higher than normal highbeams would be).
    My theory was (and is) that the sensor started working (somewhat)
    properly again and since the aim point had been raised, everything was
    high.
    The actual height would change from day to day. And some days it went
    back to "normal" (probably because the sensor stopped working again).
    As fate would have it (boo) the night before we were having the car in
    for the 15K service, the aim went back to "normal" and so the shop
    refused to investigate further. Of course, two days later it was back
    to being way high. Time passes.
    In the past few days the lights got truly, insanely high and we
    brought the car in this morning. Either we got a different tech or
    the dealership has had more cars in with this issue since the last
    time we were in, because the tech told us that (a) he's seen a number
    of cars with the problem, (B) Toyota knows there's a problem, and ©
    he's been told that when this happens the sensor should just be
    replaced. He also told us that a classic sign of the problem is if
    you turn on the lights, get a bunch of people to sit in the hatchback
    area, and see the lights move up (they shouldn't move when you load
    the back).
    So tomorrow we get a new sensor. Am keeping fingers crossed.
  2. Whitey
    Whitey New Member
    33
    My lights have been pointing low. About 3 weeks ago, I adjusted them higher. After one week, they both started going down to almost the previous low level. Next service, I'll set-up a warantee complaint.
  3. rlcarr
    rlcarr New Member
    36
    Massachusetts
    We had the sensor replaced today. According to the tech, it was "incredibly rusted and corroded". He also said that Toyota has redesigned the sensor units to be more corrosion-resistant.
