Latest Software Update Safety Recall Resulting in 8mpg less...
Discussion in 'Gen 3 Prius Fuel Economy' started by ravencr, Apr 13, 2014.
  1. neez
    neez Member
    194
    37
    Yea, recalls are expensive. Manufacturers only do them for safety reasons, to satisfy the NHTSA. For reliability or other concerns, they just issue TSB's to tell the dealer how to fix the problem, at warranty or your own expense.
  2. srivenkat
    srivenkat Active Member
    596
    93
    IL
    If the p-brake light is working, but are you really sure? I would manually apply and release the p-brake and then further have the rear jacked up so the rear wheels can be checked for free-wheeling.
    spiderman likes this.
  3. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    If you were only getting in the low 40's before the recall then you have another problem too!
  4. srivenkat
    596
    93
    IL
    Perhaps this was asked about or mentioned/answered already, but did you have any other services performed along with the software update? For example, if you had an oil change done, you would want to make sure the oil isn't past the Full mark of the dipstick and also that they used the correct weight oil.
  5. thomas goddard
    thomas goddard Junior Member
    35
    17
    Dayton, Wa
    My mileage has dropped by 10 MPG also, just had the recall done, filled the tank at the same station as always and bingo, loss of mpg. I will be returning to the dealership as soon as possible!!!!!!!!!!!!!!
  6. Mendel Leisk
    41,451
    ^Is that loss for the tankful that included the service? Maybe they had the car sitting, running, for a protracted period, and that tanked the mileage?
    Oh, and: if they disconnect the battery you lose the tripmeter data, could that be a factor?
  7. Mendel Leisk
    41,451
    Wait a sec, is that true? The indicated is lower than actual? Or typo?
  8. MonteCristo
    MonteCristo New Member
    I just want to share with the group that I have noted an overall drop in MPG as well. I drive about 2500 - 3000 miles per month with a 10/90 (city/hwy) spread. During the summer, I would consistently get 56-62 mpg between fill-ups. This number has dropped by approximately 5 mpg. Couple of behavioral changes in the engine management that I've noticed:
    1. If the weather is too hot, even when driving downhill at less than 42 mph, it still insists on kicking in the gas engine.
    2. After driving on the hwy for 60+ min and exiting, it keeps the engine running uselessly for a few minutes.
    In the winter time, the mpg is worse in general - by about 4 mpg - because it keeps wanting to warm up the engine.
    I hope this helps.
    PearlBlizzard likes this.
  9. Okinawa
    Okinawa Senior Member
    1,333
    320
    I have a 2011 Prius Two. I have not lost any mpg since I have had the recall done. No other problems because of it either. I think if anything I have gained about 2 or 3 mpg.
  10. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Reposting, since this is a multipage thread.
  11. ravencr
    ravencr Member
    117
    NC
    I got a call from Toyota finally. I plan to take mine in to have them check everything again. Still no improvement here.
  12. thomas goddard
    35
    17
    Dayton, Wa
    Mendel, I drove from the dealer after the recall was done, filled it up and this is based on that tank of fuel, computer generated mpg is now at 40.1
  13. Fore
    Fore Don't look back!
    494
    107
    Recall done no change.
  14. thomas goddard
    35
    17
    Dayton, Wa
    Serivenkat, nothing done to the car except for the recall and a free wash job!!
  15. Mendel Leisk
    41,451
    ^ That's exactly what I got. Mileage maybe a bit better post-update, the car seems to slip into electric-only a bit more readily. Maybe the suggestions about the 2 steps of the update not being completed properly?
  16. thomas goddard
    35
    17
    Dayton, Wa
    Yes, I am going to bring that up to the dealership on the 20th, the dealership just changed hands and I don't see a lot of the old people around anymore, could of been a newbee that didn't know or hasn't done many of the recalls. I called this dealership about a month ago and asked about when I could bring the car in for the recall and the SM didn't have a clue about any Prius recalls!!
  17. xliderider
    8,140
    3,276
    Honolulu, HI
    Well, that doesn't sound encouraging. :(
    SCH-I535
  18. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I'm wondering if our ideas of cause and affect here are a bit linear. I can not even begin to tell you how many times I have worked on the electronics I work on that someone has afterwards called and said "it wasn't doing that before you came out", and their new issue was totally unrelated. I have had my a$$ kicked so many times making assumptions and have learned that working backwards from a symptom can lead to another problem, whether induced or not.
  19. bwilson4web
    16,215
    It is accurate because I'm running over-diameter tires on the front wheels and they turn slower:
    • Just under 6% larger - the odometer and mph are off by that amount as is the indicated MPG.
    • Reduces transmission drag from slower rotation speeds.
    • Lets car keep up with traffic on 40 mph streets yet stay in hybrid mode.
    • Larger diameter, 14" tires are actually light-duty, pickup tires with a higher load rating than the stock or replacement tires.
    In effect, they provide an overdrive effect which of course tops "Top Gear". The indicated metrics are off but an engineer, I do the calibration correction in my head . . . for amusement.
  20. thomas goddard
    35
    17
    Dayton, Wa
    I had to re-schedule my 20th appointment to the 23rd, I took a short trip today and it looks like the computer is re-thinking as the mpg was up to 49.7 at one time. City driving seems to be a little better but no where near what it should be. Will post dealer results after the 23rd.
