Lazy, Droopy, Falling, Failing Sun Visors and what to do about 'em
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by C Wagner, Feb 18, 2021.
  1. C Wagner
    C Wagner Member
    182
    58
    Boston
    I didn't see an obvious discussion of the maintenance problems that Toyota sun visors and specifically our Prius visors face.
    My 2004 Gen II had a droopy driver's side visor. I heard you can replace for $30-70 used (with another one that will fail soon!). I heard they are $150ish at the dealer. It should be possible to fix this ourselves, and it is!
    Youtube has several general ideas about fixing this problem: use velcro, use zip / cable ties, open the visor fabric and plastic housing and repair, and others like just destroying the visor and deciding they can't be fixed.
    I found that the easiest might just be the zip tie solution, but you have to find a spot where you can get the tie into the grey bar that runs through the visor.
    Below is a video I posted to Youtube on how I got the zip tie in:
    I'll post some other people's ideas below, in case you want to do it a different way.
    mollymudpie likes this.
  2. Pdaddy
    Pdaddy Member
    153
    49
    This looks promising
    VISORiser
    SM-G960U ?
  3. Pdaddy
    Pdaddy Member
    153
    49
    That was supposed to be a link to visoriser
    SM-G960U ?
    C Wagner likes this.
