LE/SE hatch proximity / Smart key unlock research
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Zyrian, May 7, 2024.
  1. Zyrian
    Zyrian Member
    44
    31
    ATL
    2023 Prius Prime
    SE
    I have a Prime SE and the only feature of the higher trims I miss is the proximity open on the hatch - have to click the remote to unlock the car before being able to open the trunk.
    So I dug up and 6yo thread with a PDF guide for a Gen 3 on how to add more unlock buttons and found some compatible part numbers off XLE/XSE, so it's been done before, just not on Gen 5:
    84840-47040 - hatch button assembly
    89997-0E050 - rear Smart key antenna
    Prime SE button assembly harness has 3 wires coming out of it already (while the button assembly itself only has 2 pins, so hope is that unlock button will work out of the box).
    Antenna is harder - if there is no pigtail around the bumper, I'll have to figure out where to wire it - have zero idea how at this point.
    Once new button assembly comes in, I'll test it on its own hoping that placing keyfob near driver's door will be enough for the proof of concept.
    But if anyone has access to wiring diagrams or any sort of shop manuals, I'll be the guinea pig.
    Anyone with me?
  2. FreeJack
    FreeJack Junior Member
    2024 Prius Prime
    SE
    +1
    I'm with you on this one. Not having this function on my SE really bugs me. I had it on my previous car and it helps a lot in the day to day.
    I can't help you much but will surely follow your progress.
  3. Gary Van Meter
    Gary Van Meter New Member
    Carpinteria, Ca. USA
    2024 Prius
    It really bugs me too. I used it regularly in my 2013 Prius, both to unlock/lock the trunk, but really handy to unlock the passenger door as we walked up to the car.
    FreeJack likes this.
  4. Adam Adamovich
    Adam Adamovich Junior Member
    United States
    2023 Prius
    Can you do it on LE models?
  5. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    I wonder if @Zyrian had any luck with this since he posted this 8 months ago?
    That’s a feature that would be nice to have but, for me, it’s not worth the hassle and expense of modding the car to get it.
    If you’re approaching the car from the driver’s side you can always put your hand on the door handle and leave it there after the doors unlock and the hatch will then unlock after a couple of seconds. If you’re approaching from the rear you have to either use the FOB or walk a few extra steps to the driver’s door.
  6. Bastrop
    Bastrop Junior Member
    Anyone with me?[/QUOTE]
    Any update on this?
  7. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Also, if you change the settings on the Multimedia to unlock all doors once you go to open the drivers door you don't have to wait until the hatch is unlocked. It unlocks with all the other doors.
