LE / SE tire options (17" rim)
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Sep 6, 2025.
  1. Mendel Leisk
    42,331
    I'm very skeptical of that. FWIW, the only 5th gen Prius for sale with 17" rims is the Plug-In version. Non-Plugin, in Canada, it's gotta be 19" wheels, and AWD.
    WHY Toyota upped the wheels on the new Prius, ostensibly a fuel-economy centric car, is mind boggling to me. There's a guy up the block from us, carpenter/woodworker by trade, has a Ford Transit in the driveway:
    It's got 16" wheels.
    VelvetFoot likes this.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Looks like it's gonna tip over in a stiff breeze, lol.
  3. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    They do have bigger front brakes.
    Base PHEV still has the same 17" wheels/tires as the HEV.
    19" wheels are just for looks. Although, those tiny rotors aren't a show stopper, looks-wise, lol.
    My theory is that the wheel covers hide the smallness of the rotors. But that's just a theory. :)
  4. Templeton
    Templeton Active Member
    371
    132
    usa
    2024 Prius Prime
    SE
    Not sure about canada, but, in the usa, the gen5 hybrid LEs and phev SEs are all on the same 17" aluminum rims. And you can check part numbers, in the usa, all the usa gen5 phev priuses do all indeed have slightly bigger calipers on the front (likely because of the greater curb weight of the bigger traction battery). Although I believe the gen5 AWD hybrids also have the same bigger front calipers.
    About wheel choices, all other things being equal, a slightly bigger overall tire/wheel diameter is going to have less rolling resistance than an identical set up with a smaller overall tire/wheel diameter.
    However, all other things being equal, lower profile tires set up on bigger rims are going to give you more more rolling resistance than an identical overall wheel/tire diameter of somewhat higher profile tires set up on smaller rims (but this comparison of rolling resistance is only true if you keep the outer diameter of the tires exactly the same).
    My SE has 17" rims with 60 series tires which give decent efficiency and also a pretty decent ride. But, you are totally right, the higher trim gen5s with 19" rims (and the 50 series tires) are terrible in every way: worse efficiency and worse rolling resistance, harsh ride, and worse real world durability. I think toyota did the goofy 19" wheels because some people think they "look cooler". o_O
    #44 Templeton, Jan 17, 2026
    Mendel Leisk and VelvetFoot like this.
  5. Mendel Leisk
    42,331
    Ah, ok. Interesting.
  6. Winston Smith
    Winston Smith Active Member
    471
    338
    OH
    2024 Prius
    LE AWD-e
    I'll second the sentiment that the dealership not being able to re-use the OE 17" wheels with the new tires doesn't track. Brake clearance can't be an issue if they are the OE wheels, and several people here have fit 215/55r17 tires without issue.
    Tekz likes this.
  7. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    stock tires, the toyos lasted forever here, about 78k miles I think it was. Put on maxlife2's, really enjoy these too.
  8. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    It's weird how some people like a tire and others hate it.
    2023p likes this.
  9. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    That was the same thing in my case when I bought the base SE PHEV here in Cda, dealer declined using the 17” OEM wheels with the new tires (of my choice as part of the deal I got) which were 215 55 17s and said something about the tires are wider needing at least 7” width on the wheels whereas the OEMs were only 6.5” - likely they didn’t want to risk any issues (for any liability) but they supplied the new set of wheels anyway and it cost almost $2.6K for entire set of wheels+AWT at dealer’s cost. The OEMs that came with the vehicle are just stored in dealership for free for 3yrs
  10. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    That's just not right. According to sizing standard tables, 7" is the ideal width for 215/55R17, not the minimum.
    Minimum is 6", maximum is 8".
    Blackat likes this.
  11. Winston Smith
    471
    338
    OH
    2024 Prius
    LE AWD-e
    Could you have taken the car with the original wheels to a shop to get whatever tires you wanted, or was it important for you to have two sets of wheels?
  12. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    That was my thinking too but the dealership svc techs didn’t want to take any chances and also consulted the local tire shop they sourced the tires from. Again, I assumed they didn’t want to face any liability issues and since they covered all the costs including tires storage, didn’t matter to me.
  13. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    I probably could have done that but there’s the hassle and I preferred all is installed when I pick up the vehicle. As part of my deal, they asked me I can get any winter tires I wanted which I selected the Michelin CC2s but due to the sizing, they insisted that the wheels needed a wider size. Didn’t matter to me at the EOD as they covered all the costs (2nd set of ART aftermarket wheels with wheel locks+tires+mounting+balancing+3yrs storage for the OEM set). All that cost close to $2,600 CAD after taxes! Not to mention, they threw in a 3yr 80K ECP coverage for free. I don’t mind the 2nd set of wheels since they looked better than the OEM alloys with the hub caps. Almost looks like the nightshade edition! As a backup, I have a 2nd set of the OEMs should I damage the current wheels!
  14. Winston Smith
    471
    338
    OH
    2024 Prius
    LE AWD-e
    I'm in the minority on this, but I think the 17s with the wheel covers pulled off look great. If you were local, I'd offer to buy.
    I pulled the covers off the wheels in part because I didn't want them stolen. In Toyota fashion, those covers are priced as if they were made of faberge and bald eagle eggs.
    reservoirblue likes this.
  15. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    I disagree, the hub caps looked better with them on than off. Not sure why Toyota selected that design of rims as the OEM but whatever…
  16. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    Hammersmith seems to agree with your assertion. I can't figure out how to quote the entry from the other thread but here it is copied:
    "205/55R17
    Pros - Should be about the same mpg. Probably very, very slightly better at city speeds and very slightly worse at highway speeds. CC2 available now.
    Cons - Tiny bit smaller tire. Lose about 1/8" ground clearance and about 3/16" sidewall. CC3 not available yet - maybe not until next year.
    215/55R17
    Pros - Very slightly bigger tire. Less than 1/8" more sidewall and negligible increase in clearance. Lots of great tire choices.
    Cons - Small but noticeable hit in mpg due to increased weight and air resistance. Starting to be a little wide for the wheel, but still acceptable.
    215/60R17
    Pros - A full 1/2" more sidewall, and 1/2" more ground clearance over stock.
    Cons - Bigger hit to mpg over 215/55R17. Not many great tires in this size, but some are available. Also a little wide for the wheel(but still acceptable).
    #6Hammersmith, Sep 6, 2025"
    Tekz likes this.
  17. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I've gone crazy trying to find tires which might be both longer wearing AND with a reasonable rolling resistance. So far, I'm considering the Michelin Energy Saver Green X in a 215/55R17. The treadwear for that tire is UTQG:480 The treadwear for the Bridgestone Ecopia is UTQG:600. THAT SCARES ME. My Ecopias only have 16,000 miles on them and I doubt they'll make 18,000. This despite Bridgestone claiming a warranty of 85,000 miles for the Ecopia EP422 Plus.
    I know the two things I'm interested in are diametrically opposed - tread life vs efficiency. I like getting in my car and having 59 available miles on my traction battery each morning, but I'd give a little of that up for longer tread life.
  18. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    And as an added bonus, sportier handling!
  19. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I've thrown another tire into the mix which may combine what I'm looking for. The Continental True Contact Tour. It weighs about the same as the Ecopia. It has a UTQG: 840. It is not identified as an LRR tire, but its rolling resistance is very low (just under the Michelin Green X). Since it rains a lot in Florida, the Continental also has the best wet braking (3ft shorter than the Michelin). I guess it's a crap shoot until you put them on the car and try it out.
  20. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    The best tires I ever had were Michelin Energys that were stock on my 2000 VW TDI Beetle.
