LE / SE tire options (17" rim)
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Sep 6, 2025.
  1. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I ended up going with Contiental TrueContact Tour 54 in a 215/55R17. My speedo runs fast by about 2mph. GPS indicates 50 when the speedo says 52. The tires do not yet have 300 miles on them there a signs of only minimal impacts to range and mpg. My primary mode is EV use around town. My daily range remains so far between 58 and 59 miles. If you factor in a bit of inaccuracy because of the speedo (.96%) that means my true range has been reduced to between 56 and 57 miles - not earth shattering. They reportedly have much better wet handling than the Ecopia. I'll see in a year how they compare in terms of wear!
  2. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Just to be clear - the 4% fast on the speedometer is not due to the tyre change. That would have reduced speedometer and distance readings readings by about 0.4%. The new tyres have a slightly bigger circumference.
    And an deliberately high reading on the speedometer (arising from legal rules about speedometers) doesn't mean all the other readouts are skewed by the same amount, so a 4% "true range" adjustment shouldn't apply.
  3. Mendel Leisk
    42,326
    Yeah by my calculation the 215/55R17 has a mere 1.25 mm taller sidewall, compared to stock 195/60R17:
    (215*.55)-(195*.6)=1.25
    And the 19” stock tire, 195/50R19, has an outside diameter 11.8 mm more than stock 17”, a much greater variation:
    ((195*.5*2)+(19*25.4))-((195*.6*2)+(17*25.4))=11.8
    I hammered out the above with an RPN (Reverse Polish Notation) calculator app thus;
    195
    Enter
    .5
    Times
    Times
    Enter
    25.4
    Times
    Plus
    195
    Enter
    .6
    Times
    Times
    17
    Enter
    25.4
    Times
    Plus
    Minus
    And for a sanity check, verified here:
    Tire Size Comparison
    #63 Mendel Leisk, Feb 12, 2026
    VirginiaLeePrius likes this.
  4. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    Well heck, so much for my logic. I guess perhaps my speedo has always been slightly different than the displayed GPS results but I was never focusing on it. Looking at "Tire Size Comparison" there is hardly any difference at all (.1, .2 mph). That's even better news that my range hasn't really been impacted ...yay!
    Thanks for the comments.
  5. Mendel Leisk
    42,326
    Yeah I think someone else mentioned: speedometers display slightly high, by legislation, in a mostly-vain attempt to slow down cars and reduce carnage. The car knows the more accurate speed behind the scene (assuming stock tires), and the odometer should be accurate as well.
  6. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    My observations in the past, with other cars as well, have been that the speedometer is high by 2-3 mph. Not a %.
  7. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    LOL ... quoting my own post but ...
    I just wanted to provide some update. Since putting on the Contiental TrueContact Tour 54s in March, my daily range from the traction battery is now down to 52 miles. I lost about 12% of range. Still not bad given how quickly I went through the original tires. Maybe after a few thousand miles more I'll gain a few back. Just an update for anyone intrested.
  8. Bob P.
    Bob P. Junior Member
    Western PA
    2023 Prius
    LE AWD-e
    I had a set of CrossClimate 2s in 225 55R17 on my 2023 Prius LE eAWD and made it through a tough PA winter with no problems. The tires were installed at Costco, and I've had zero problems with rubbing, etc. Had the alignment checked and no problems there, either. I took a 2 -3 mpg loss on mileage, but I can live with that for the increased safety in inclement weather.
    reservoirblue and Tekz like this.
  9. Mendel Leisk
    42,326
    I’ve heard Costco will only install specd sizes, was there any resistance from them?
  10. bob12345
    bob12345 Junior Member
    30
    Knoxville, TN
    2024 Prius Prime
    SE
    Does anyone have experience with the newly released GoodYear Assuarance Maxlife 2? I imagine they are not great in the snow compared to Michelin Crossclimate, but for those of us who do not see a lot of snow, it appears to be a decent all season tire on paper. A 85K warranty, 820 treadwear rating to match, and good reviews on Tire Rack. If they do go on sale when Toyota dealers have their tire seasonal tire sales, its another another advantage too.
