Lead Headlight Fabricator Seeking Input - LEDs, Carbon Fiber, the Works!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jonvo, May 5, 2010.
  1. jonvo
    jonvo New Member
    34
    SoCal
    It was an almost complete rebuild of the trim accent. The headlight sealant on the Prius is pretty tacky as with most others'. Wait till you work on some domestic cars or Ducati bikes .... they use rubber cement in which baking or heating will not work. You'll have to use an exacto knife to "cut" the sealant and pry it out by force.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Ive opened up my 08 CTS, 06 Escalade & M3 lights, but none were like the glue on the Prius. My Yuknon Denali was not bakeable, had to cut :mad:
  3. ralue
    ralue New Member
    Prosper, TX
    I was going to put an SMD strip where the faux LED strip is - similar to your fab - but didn't want to pull the headlight out or cut through the sealant... was more of a fun idea than a desire to do a major mod. So, I upgraded my foglight bulbs to xenon 55w and added the SMD strip to the grill. I'll take a picture soon... nothing all that amazing, but kinda cool.
  4. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Bump. I definitely want to see how this turns out. If nothing else, I want to open up these headlights to take out the reflectors making it more like a euro-headlight. I have had someone very important bugging me about it for a long time. :p
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Like these? Euro Spec Japan Prius Headlights
  6. jonvo
    jonvo New Member
    34
    SoCal
    Pictures updated.
  7. brad_rules_man
    716
    76
    Effingham
    Yeauh. :B
    Heh, do they drive on the right side of the road there? I mean.. will they be aim-able here?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Funny you ask.....they do drive on the other side of the road, so the cutoff is on the wrong side, but I'm retroing a set of HID projectors :whistle:
  9. jonvo
    jonvo New Member
    34
    SoCal
    Spot on sfv41901. With our BPR system, you can swap the cutoff to suit your region of residence.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
  11. jonvo
    jonvo New Member
    34
    SoCal
    sorry. Bixenon Projector Retrofitting system.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Oh......that makes sence. The projector that I'm using is made in both LHD & RHD versions.
    On a side note regarding the Japan Spec lights.....for those that already have HID US Spec lights, you can remove the bulb holder w/bi-xenon solenoid/reflector shield & swap them into the Japan Spec lights to give you the correct cutoff.
  13. brad_rules_man
    716
    76
    Effingham
    Ah, well the thing is.. I was just wondering if those amber bits are added in, and would be similar to the eurospec just by removing them as you did in one of those pictures. Sounds a lot easier/cheaper.
    Don't really need the HIDs on that car. I have the LEDs on mine, and had HIDs on others. The Prius HIDs have always been a let down compared to the bmw I had that was not only much brighter, but even turned corners with me as well. /shrug
    I never did understand why they wouldn't use projector housings in the gen2. And I don't really understand their implementation of the LED lights in the Prius. They are kind of weak, and require two projectors. Then you look really cheap when you engage your halogen high beams.
    i.e. Made the interior cool, and the car cooler.. but put the mfd on some old fashioned vacuum fluorescent display instead of an LCD.. and that old screen for the a/c.. It's just stupid in my books. I hope someone will come out with another replacement screen.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Every headlight that I've pulled apart has allowed the amber reflector to seperate from the housing, so I dont see what it cant be done on the GenIII
  15. jonvo
    jonvo New Member
    34
    SoCal
    Carbon fiber reflector almost done and projector retrofitted. Need to prep it for UV coating and we're good to go. I will post pics up later tonight.
    This project is almost at its completion. Turned out pretty nice for being a prototype. Just need to mount on the car, wire up the headlights and aim the lights to NHTSA specs.
    If anyone here have any tips for the next project, please let us know.
  16. Manksgloob
    Manksgloob Member
    243
    Bravo! What you've done here is exactly what I wanted to do. (How much would you charge for this, btw? ;))
    For your next project you could look into custom housings for rear LEDs (make everything back there into LEDs).
    Right now I've replaced just about every exterior light (except for headlights) into LEDs -- but these are those drop-in units with diodes arrayed so they output light like an incandescent bulb (in all directions). And I had to change out the flasher relay -- not a fan of extra resistors. Don't get me wrong, it looks great, but not as great as it could be if the housings were designed for LEDs to begin with.
  17. jonvo
    jonvo New Member
    34
    SoCal
    Status updated as of 5/26. Pics of carbon fiber and projector retrofitting on page 1, post #2.
  18. Supreme
    Supreme Hypebeast
    182
    Philly
    wow that is looking incredible.
    When you removed the orange reflectors, are there visible open mounting holes left in the light? Looks like the reflectors were held in by some sort of extended tab.
  19. jonvo
    jonvo New Member
    34
    SoCal
    Thank you for your kind words. Regarding the reflectors, the mounting holes/tabs for the signal housing is not noticeable however the same is not true for the chrome trim (trim that outline the entire headlight.
  20. Manksgloob
    Manksgloob Member
    243
    Wow! The carbon fiber makes that look even more amazing!
    Out of curiosity, why is it okay to use projection lenses for halogen but not HID bulbs? I mean, in theory couldn't the HID light be directed in the same fashion as the halogen ones? Or is the issue something else (heat?)
