Leaf Comes Home
Discussion in 'EV (Electric Vehicle) Discussion' started by DaveinOlyWA, Jan 19, 2011.
  1. drees
    drees Senior Member
    1,782
    247
    Lucky - 770 kWh of electricity and it only cost you about 10c / kWh. If I used that much electricity in a month my cost would be appx $158 or 20.5c / kWh...
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya but you have all that wonderful weather!
  3. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    dueling Leafs getting a boost at Younkers Nissan in Renton
    here we are parked in front of Cafe. i am first, the last in line is a red Tesla you can barely see.
    there is a total of 7 Leafs in Wa right now. here are 5 of them
    52,849
    what's that ugly dark blue thing 2 cars back?
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    another thing about the Leaf that i like is the Map views. there is the "birdeyes view" or 3D. it also has an adjustable angle and i find it to be MUCH easier to use especially in congested downtown areas because it allows turns and streets to be seen better and anticipated than the normal top down 2D that the Prius has.
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i think the biggest reason i decided on buying a Leaf was due to the level of commitment Nissan has shown towards making the technology work. its not just lip service here. i have seen many other EVs "come" and go, well actually none of them actually got here.
    i have also seen token efforts by everyone else, none of which instills a lot of confidence in me. if they are not confident of what they are doing, how can i trust them to do it right?
    but Nissan announcement of the manufacturing facility in TN really says they are "all in" for EVs. here is the battery plant startup. in the background is the 5.2 million sq feet Leaf assembly plant where 150,000 Leafs will be built beginning fall of 2012. to support them the battery plant will put out 200,000 traction battery units.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    bumper sticker alert; seen on a red Leaf in Encinitas, CA.
    More Pious than a Prius
    AWESOME!!
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I congratulate you on setting expectation levels realistically in the article. I think the Leaf will 'fit' many owners, and be the best solution for most that it does fit. I am also aware that it does not fit everyone and you made that very clear, I am proud of you.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    here is Carwings week in review for summaries;
    on tuesday the day i took Prius for recall work. required dropping it off at dealer in morning, taking SO back home to get other Prius. then going back and paying for it (did oil change) and parking it in a place so i could pick it up after hours (they shut down lube lot at 5:30)
    so a bunch of trips with boosts periodically during the day.
    the real test was thursday and it turned out to not be much of a test. was commute to Centralia. was a bit longer because SO took co-workers out for a joy ride at lunch.
    but trip was mid 20's in morning, ran heat all the way up and back. only drove 60-63 mph. 40 miles on freeway (exit 101 in Tumwater to exit 81 in Centralia) was concerned after hearing about lunch trips which only added a few miles
    but RT mileage was 64.9 miles and had 17 miles of range left when returned so was not even a challenge as the Leaf handled it very well.
  11. bisco
    52,849
    with no engine, how is the mechanical/road/wind noise on the highway? sorry if someone asked already.
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well... as u well know, i have talked about how quiet the Prius was. but after driving the Leaf for a few weeks now, i had to put gas in the Prius on 'Thursday. i am sad to say that the car seems to have gotten very loud, rattly and full of vibration somehow
    but as to the Leaf, its not really that bad. its definitely quieter than the Prius and the road noise is not as noticeable as i thought it would be
  13. bisco
    52,849
    thanks! do you think noise improvements could be made without too much loss of efficiency and at a reasonable cost, or do you think they've pretty much got it covered?
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i am not sure you could do a whole lot better. the headlights protrude from the hood like a pair of bug eyes. the reason; they create an air dam that channels air around the side view mirrors. not doing this caused a prominent whistling sound that was very noticeable in the car at highway speeds.
  15. bisco
    52,849
    can't wait to take one for a test drive! all the best with yours.
  16. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    I LOVE this pic :) any chance of a high res for a wallpaper?
  17. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Yeah i just noticed the two gas guzzlers are parked in front of signs which say "Antiques"!! :lol:
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Dave, why is your hood up in the photo? Were you changing the electrons?
    Tom
  19. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    You mean SUV & the Prius ? ;)
  20. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    They did all kinds of things to reduce wind noise (which gets very noticeable in EVs). Like changing the headlights shape and even changing the antenna shape. One thing they can do is to lower the rear of the car (like Prius) - that would reduce cd & noise. But for that they need a new floor plan for the batteries.
