Leaf Comes Home
Discussion in 'EV (Electric Vehicle) Discussion' started by DaveinOlyWA, Jan 19, 2011.
  1. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Yep, funny how a certain "EREV" has a CVT instead of a single speed gearbox. Almost as though it were a hybrid....
  2. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Is the manual separately purchased ?
  3. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Indeed, the Prius configuration multiplies rpm's from the traction motor to the motor/generator while in the Volt they are decoupled. Of course, in EV's there's only one which simplifies the drivetrain.
    Tesla also uses a 1 speed.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  5. Flaninacupboard
    1,297
    213
    Midlands - UK
    That's because it's an EV. The Volt isn't, nor is the prius. They are hybrids.
    Can the Volt's traction control be switched off?
  6. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    We had discussed this in a different thread. When you look at mg2 driving the wheels, the configuration is quite like the leaf with a single gear ratio. This is unlikely the cause of failure. Although MG1 is a more likely culprit, it too is unlikely to be the failure point. The HSD gearing or electronics seem the most likely points of failure. Making the HSD beefier might have added weight and costs. Making the electronics more tolerant might have added costs. No one seemed to have the specs of the mechanical or electrical limits of these components.
    The leaf has a fixed gear ratio which seems like the best choice for an EV, but the motor must be specified with enough power at higher speeds. GM decided that the volt's traction motor did not have enough power at high speeds so implemented a blending of generator power through a universal gear set. This does not seem like a bad trade off and the volt only has an eCVT at higher speeds (>70 mph in ev mode). The tesla had a similar problem and originally had a 2 speed transmission. They improved the power of the Tesla motor and were able to simplify to a fixed gear ratio.
  7. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The manual did not contain a single warning on drivetrain damage if certain maneuvers are attempted.
    Nissan must have a lot of confidence in the design of the EE.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    just the fact that they allow us to turn traction on and off does speak volumes about their confidence of the drive system
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    first electric bill where the Leaf was charged the whole month and my cost went up...sort of.
    my average kwh cost was 10.2 cents, it was 10.3 this time. now that is total cost including taxes, connection charge, meter charge, etc. i took out the kwh used by the car and it still would have been just under 10.2 kwh. and i am on metered rates based on consumption not time of day so cant get better rates like u lucky San Diego dogs!@!
