Leaking coolant from Inverter reservoir, Please help!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Justin Henderson, Aug 10, 2021.
  1. Justin Henderson
    Justin Henderson Junior Member
    Salt Lake City
    2014 Prius v wagon
    Hey all,
    Long time reader, first time poster here. I have a 2014 Prius V that I'm hoping to get some help troubleshooting. My wife was driving yesterday and the check engine light and hybrid system light came on. She got home and I checked the error codes and codes P0A93 an P0C73 indicating Inverter "A" cooling system performance. I did some reading on this site and on youtube and figured it was most likely a failed pump. I went back out to see if I could test the pump. I noticed that the inverter reservoir was nearly empty and a puddle of coolant on the driveway. If I understand correctly, if it was the pump, it shouldn't leak like that. At any rate, today, I pulled off the bumper so I could access the pump to really see if I could hear/feel it running. I topped off the reservoir, turned the car on, and I could see swirling in the reservoir, and could feel fluid running through the hoses.
    When I took a closer look at the inverter radiator, I could see coolant starting to drip from the foils. I'm thinking it got dinged by a rock or something.
    Am I correct in my thinking that if I can see coolant coming from the radiator, it's the most likely culprit and pump is OK?
    I've tried to find instructions on how to swap out the inverter radiator but not seeing any. Apparently this hasn't happened to many people?
    Any help or assistance would be appreciated. I live in a small town in northern Idaho and non of the local mechanics work on hybrids. The nearest Toyota dealership is an hour away and will cost a bunch to get towed to, so I'm trying to do it my self to save some money. I just don't want do any damage or make things worse.
  2. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Swirling in the reservoir and a leak from the radiator is a good sign that it's a radiator nick.
    How comfortable would you be R&R'ing the inverter coolant radiator?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    IF......you have a good view of the punctured radiator, you probably also should have a good view of how it is mounted and connected.
    Right ? Wrong ??
    Note: Before you go out and buy a new radiator, check the hoses and their connections first.
    Might also want to ask some local mechanics if there is a radiator shop nearby.
  4. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    If i can find some sort of instructions or walkthrough, I think I'd be fine to do it myself. Just called the dealership that's an hour away, they said it would cost $2000. Which is insane to me. The part is only like $80-120 online. I called around to multiple mechanics in my area and people are either booked out more than a month or they don't touch hybrids.
    Tim Jones likes this.
  5. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    I pulled the bumper off and could see the radiator fully. As far as I can tell, all the hoses are connected ok. I can take pictures when I get home from work.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Probably a waste of time. It's just not the same as BEING there.
  7. burrito
    burrito Active Member
    274
    114
    Hopefully these excerpts from the repair manual can help.
    Air_Boss and Tim Jones like this.
  8. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Doesn't sound that rough..... I've done a Head Gasket and The Dreaded Master and Pump + the traction battery and egr (entire system)
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Rocks have been known to ding the radiator and the inverter radiator causing coolant leaks.
    That is why I put aluminum mesh behind the lower and upper grill openings.
    Something to consider doing while you are replacing the inverter radiator.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    I did the same with a black powder coated expanded steel diamond mesh gutter guard. It stops everything larger than 1/4 inch or so, even smaller, if it hits the mesh. Cost no more than $3-4.
