Leaking from oil pressure sensor?
Discussion in 'Gen 3 Prius Main Forum' started by unigeezer, May 31, 2023.
  1. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    81
    Sacramento, CA
    What size socket is that?
  2. Mendel Leisk
    42,343
    24mm deep socket is required, according to attached:
  3. Gloria&Suzanne
    81
    Sacramento, CA
    Jiffy Lube changed my oil only 2k miles ago. Guess what I discovered when I removed the valve cover. IMG_20260711_202633685.jpg IMG_20260711_202643698_HDR.jpg IMG_20260711_191558615_HDR.jpg
  4. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    A valve train?
    Brian1954 likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    Minor wear on cam lobes?
  6. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    jiffy lube, HUGE mistake..... We made a lot of money replacing engines with leaking/missing drain plugs
    and loose/double seals oil filters..... And cheap oil.
    I doubt they've been using synthetic oil. Or cheap crappy synthetic oil....
    Those places or the worst thing you can do to any car!
