leaking Radiator (or hose). Please help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by master4g, Jun 30, 2009.
  1. master4g
    master4g Junior Member
    24
    CA
    I
    Hello. New to the Prius here. I bought a salvaged 2005 prius with 45,000 miles on it. Before I bought it, I had it inspected by AAA with their "80 point pre-purchase inspection" to see if it was worth buying. The reason it was salvaged was because there was a front end collision and the front bumper and left headlight was replaced (thats it). The only non-consmetic thing that AAA pointed out to me was that the oil needed to be changed and that the Radiator hose was seeping and they recommended that I have the hose changed or maybe even fix it by just replacing the hose clamp.
    Now it has been about 1000 miles since I purchased it and there has been no problem in terms of engine over heating or anything. I received a coupon for a $20 oil change at the toyota dealership and they also had a coupon for a free multi point inspection of the car. So i took it in for an oil change and inspection and knowing that it was a free inspection (especially by the dealership) I was expecting them to come back to me and exaggerate a problem and quote me a inflated price to fix it.
    And they did, and they said the radiator is leaking (possibly cracked) but they didn't tell me for sure, they said that they would have to remove the whole radiator to see and would have to do some test on it, etc.... and then if it was bad they would replace it and it would cost me over $500. They would also charge me several hundred $ just to take the radiator out and check if its leaking.
    I told them that I would like to hold off on that, because I remembered that the AAA inspector said just the hose was just seeping and they didn't mention anything about the radiator being cracked.
    I have taken some photos and would like you guys opinion on who I should believe: Money hungry toyota dealership, or AAA ?
    Also, do you guys think its safe to drive while i'm figuring this out? I have already driven over 1000 miles like this. The coolant fluids seem to be filled enough.
    The rest of the radiator has no signs of leak or any damage. One thing to point out (not sure if its just me being paranoid) is that whenever i drive the car and then park and turn the car off, there is a buzzing sound from the driver side of the engine (around the fuse box area) for several seconds. It happens every time I drive and someone suggested it had to do with some radiator fluid reserve filling up or something. Does this nose happing on on prius's?
    Thanks a lot.
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Thank you for the clear photos, they really help
    The buzzing may be the coolant pump running, to transfer coolant to the thermos.
    The upper hose does look like it was put on cockeyed. The radiator header, like on almost all new vehicles, is plastic.
    First step, get a new upper rad hose, and new hose clamps of the proper spring design, same as was from the factory. Drain the rad. Once you have that new hose, use a pair of pliers to compress the clamp and slide it down the hose a few inches.
    Use a new and very sharp utility knife or razor blade to slit the upper hose where it hooks up to the rad. You must peel the upper hose off once it is slit. Do NOT attempt to twist the hose off the radiator, you'll probably crack the outlet at the header tank. I learned that the hard way around 8 years ago with a Honda
    With the hose off, slide the new hose clamps onto the new hose. Put the engine end on first, then carefully put the rad end on, taking care not to twist it too much. It helps to smear a bit of Vaseline on the outlet so the hose slips on easier
    Use the pliers to compress the new clamps, and put them where they belong. Now comes the fun part
    You're going to have to be VERY careful how you bleed the cooling system, as you also have to deal with the thermos. It's very important to get this right, or you could ruin some pretty pricey parts.
    I'd recommend subscribing to either the Toyota techinfo site, or All Data DIY, to get the factory-correct refill and bleed procedure
    It could be the plastic rad outlet is cracked right at the header. But it does look like the hose is very cockeyed, and leaking. Resist the urge to put on worm-gear hose clamps, you could overtighten and crack the plastic outlet
  3. master4g
    24
    CA
    I
    Thanks for the detailed reply. Just a follow-up. If the actual plastic radiator head is cracked, do I have to replace the radiator, or is that a separate part. Also, do you think its ok to drive the car in this condition?
    Also, anyone else with opinions out there? Thanks
    Oh Yeah. I did some reading into bleeding the coolant and there are two things someone can do. One is just to remove the air from the existing cooling system, and the second is to completely drain the old fluid and then replace with new fluid. In my case of changing the hose, which would you think is appropriate.
  4. Patrick Wong
    18,200
    6,464
    If the plastic radiator tank is cracked then the entire radiator must be replaced. I do not recommend continuing to drive the car indefinitely while in this condition (especially on a long freeway trip in hot summer weather.)
    Considering you have 45K miles logged, when changing the radiator hose it is not necessary to completely drain the old fluid. Attach a vinyl hose to the radiator drain, open the drain and let out a couple of quarts of coolant into a clean drain container, then close the drain. That should be sufficient so that when you remove the old radiator hose you won't have a big flood of coolant everywhere.
    If the drained coolant is clear pink without sediment then you can reuse. Otherwise buy a gallon of Toyota Super Long Life Coolant (around $20 or so) and use that to replenish. Check the radiator and overflow container a few times after the engine has been run and then cooled down, replenish coolant level as needed.
    When buying a new hose and clamps I suggest you buy from the Toyota dealer's parts dept, resist buying some cheap aftermarket alternative.
  5. master4g
    24
    CA
    I
    Hey. I have used some brake cleaner and cleaned up the coolant rust to see if it makes things clearer.... (refer to photos attached).
    As you can see, the actual radiator part is metal so no worries about plastic cracking. Also, this area seemed like the only area which had the coolant leak and when i cleaned it off and examined the area, I couldn't see any damage on the actual radiator part, so most probably it was just that hose being on loosely. The Hose also looks like it has no damage on it and looks in very good condition
    Do you guys think i can save some money and time and avoid buying new coolant, new hose, new clamp and all that time to drain it and bleed it..... by just trying to stuff the hose more into the radiator head? or even just slightly loosen the clamp and push the hose in all the way and tighten it again?
    Thanks for the help
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There had to be more damage than a headlight & bumper for the car to be totalled & branded with a salvage title. Hope you didn't pay much for the car.
  7. master4g
    24
    CA
    I
    Thats off topic... but yes, that was all that happened, both side fenders, hood, and all other parts have origional vin on them, plus I looked into it deeper and thats all that happened. I wouldn't have bought it if it had serious damage on it.
  8. jayman
    13,439
    640
    Winnipeg Manitoba
    Huh, it IS metal! The header outlet on my FJ is plastic. Go figure
    Looks like a fairly easy repair after all. You may be able to ditch that clamp, it may have weakened. Should be safe to use a worm gear clamp, but don't go crazy tightening it
    Just square up the hose on the outlet and that should stop the leak
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Nice cleaning job! Which brand cleaner did you use?
    If possible I would try to pull the hose out some but not completely off, clean the metal surface, apply high grade grease, and then push the hose fully in and finish with a worm gear clamp as jayman suggested. The grease should help sealing.
  10. Patrick Wong
    18,200
    6,464
    I'd be cautious about applying either grease or brake parts cleaner on the rubber hose. Both substances may cause the rubber to deteriorate.
    Rather, I would have used water to clean off the antifreeze deposits since that is water-soluble.
    In any event, I hope that replacing the hose clamp and moving the hose to the correct position will take care of the seepage; if not then try replacing the hose with a new one.
    If the sheet metal at the front of the car has the original VIN stickers and those stickers are undisturbed, then my guess is that the drivetrain was impacted by the accident. I'm wondering whether the engine, transaxle and/or inverter may have been replaced.
  11. jayman
    13,439
    640
    Winnipeg Manitoba
    Vaseline may be used here, I've used it over +20 years with no issues yet. The hose will almost always show signs of failure from rot after +10 years of use.
    Actually, the best and safest lube to use on a cooling hose is .... coolant. Dip your finger in straight coolant - or the Toyota SLLC premix stuff - coat the inside of the hose and the outlet, and slip on
    You know, after re-reading the above several times, I'm just going to have to accept that it can be read in such a way as to have a shockingly wrong meaning.
  12. master4g
    24
    CA
    I
    ok, i finally had time to try and fix this so i tried just pressing the clamp and just trying to shove the hose in deeper, and i was able to get it in a little more..but now (a day later) the thing is slowly leaking. there is coolant left wherever i park my car and also on the part under the hose. I think that the clamp is just not tight enough anymore so i will go get one of those warn gear clamps as suggested earlier. Any other suggestions
    My question now is: would you guys suggest i stick with toyotas super long life cooalnt? or any other coolant should be OK? or water? I only need a little bit and want to know if i can skip driving all the way to the dealership and then buying the huge container of coolant when i will only use 1/10 of it.
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    Don't use the cheap green stuff - it will not be compatible with the coolant you now have. It's possible to find a non-silicate, non-nitrite, non-amine, hybrid organic acid coolant labeled "long life."
    If you can find that stuff, and it claims safe to mix with other brands of long life coolant (Eg, compatible with Toyota SLLC), then it should be safe.
    If the tap water is sourced from wells, never add hard water to a cooling system. Distilled water is best. Adding water will bugger the freeze protection (Probably doesn't apply to where you live) and the boil point
  14. master4g
    24
    CA
    I
    Ok, I went and bought some toyota SLLC and my question now is: the coolant has been seeping out of the hose and later it even dripped out of that same spot until I put on that Worm gear clamp, and now it has stopped seeping or dripping.
    at the rate that it was coming out, I dont think that air got into the radiator/cooling system. What do you guys thing? Do I need to do the whole air bleeding, radiator filling, heater blasting thing? or can I just simply full the coolant reservoirs which have gone down a little?
  15. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    How much coolant did you need to add? WAs the overflow bottle empty? There is probably no need to bleed the system. Just fill it up, drive it around and check the level. When I filled mine, I had trouble bleeding it, but after driving it a couple of times, and topping it off 2 x it was good.
  16. master4g
    24
    CA
    I
    the reservoir which is next to the radiator (bottom resevoir?) was on low and the top one was near low as well. I just had to fill up less than 10 oz. which is why i was trying to skip out of buying the whole gallon.
  17. Patrick Wong
    18,200
    6,464
    If the reservoirs still contained fluid, then you don't have to worry about air getting into the system. I suggest that you keep an eye on the fluid level when the drivetrain is cold, to make sure that no other leaks exist.
  18. jayman
    13,439
    640
    Winnipeg Manitoba
    With the engine cold, squeeze the radiator hose. If it feels as if there is air in there, you may have to go through the bleeding process. If the hose feels full, and when the coolant transfer pump runs there isn't a deathly groaning/screeching sound, there shouldn't be any need to bleed the system
  19. nthach
    nthach New Member
    174
    Dex-Cool or its clones such as Prestone is a no-no too. Peak Global Lifetime or it's Wal-Mart cousin Global Extended Life is OK but there is a consensus over at BITOG to whether or not it has 2-EHA and sodium neodecanate which causes all the issues with Dex-Cool.
    I used soap and water without issue for years. I've seen mechanics use silicone spray or grease.
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    I agree. I personally will use the genuine Toyota SLLC. Prestone advertises a "universal" long life coolant that may be compatible. I personally do not think the potential "savings" are worth having major problems
