leaking Radiator (or hose). Please help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by master4g, Jun 30, 2009.
  1. nthach
    nthach New Member
    174
    Prestone All Makes/All Models=Dex-Cool in drag, it has the same chemicals in it. Peak Global Lifetime has no 2-ethylhexanoic acid or sodium/potassium neodecanate - or so what Old World Industries says. There's rumors that Peak Global Extended Life at Wal-Mart isn't the same as the Lifetime.
  2. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Not to hijack the thread, but recently I drained small samples
    of engine coolant from all three drain points and observed that
    the stuff is as bright pink as the day it went in. At over 100K
    miles. What does that say about the chemistry, if anything?
    Vaguely related, where can one get *small* quantities of those
    test strips for coolant and brake fluid?
    _H*
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Tells me that Toyota knows what they are doing. Remember back when motors had the green stuff? If you went 2-3 years, the rad was a scaled-up mess
    Regarding the test strips, I've never seen them sold for individual use. I suppose you've tried all the usual suspects? Eg Autozone, PepBoys, NAPA, etc
    This is a typical quantity of test strips
    Run-Rite.com : PRODUCTS: Fluid Rx Multi-Fluid Test Kits
    Just the ticket if you decide to start reparing Prius cars on a huge scale!
