Leaking rear strut/shock
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kermit262, Aug 19, 2015.
  1. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    My driver side rear strut/shock (would someone educate me on the correct term) has started leaking recently (I've attached a pic and would like for someone to confirm my diagnosis). Its counterpart on the rear passenger side is bone dry. My Prius is a 2010 with 78,000 miles, mostly city driving.
    Does this fall into normal wear and tear parameters? I love my Prius for being rock-solid reliable, and so this is a bit disappointing. Also, what should be a reasonable price for a shop to fix this? I've put in some calls but haven't heard back. Thanks.
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    This is usually caused by unbalanced/out of shape/bad tire or bent rim, and no it is not normal. Have those fixed prior replacing shock. I would also check hub since it had been likely caused by bump and those hubs are not very strong.
    I have take off OEM rears laying some around, PM if interested.
  3. peterjmc
    917
    189
    Clarksburg, MD
    That leaking shock should be replaced. The fluid leaking is the internal fluid used to dampen rebound.
    Some of the major manufactures recommend shock/strut replacement at 50,000 miles. Your mileage may vary though depending on your driving conditions and driving habits. The general test to verify if your shocks struts need replacement is to do the bounce test. The procedure is to push down on a corner of the car and if it rebounds more than twice, the shock/strut assembly in that corner should be replaced.
    Worn shocks can contribute to excessive wear on tires and poor alignments. It's a good rule of thumb to get an alignment shortly after the shock/strut assembly replacement. I generally get them done shortly (500-1,000 miles) after I replace shocks or struts to provide the new components time to "settle"
    mjoo likes this.
  4. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I would replace both rear shocks at the same time so the suspension will be even.
    peterjmc likes this.
  5. peterjmc
    917
    189
    Clarksburg, MD
    I agree with OBJ. Both rear shocks should be replaced. With 78,000 miles on your current setup, I would also consider replacing all four.
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    A "strut" provides position control to the wheel. A "shock" just provides dampening. Position control in some sense but not in the way a "strut" does.
    That shock is leaking, and they don't contain a lot of fluid. It's done. It's always a good idea to replace them in pairs. The front "struts" are rather more expensive I expect, and if not leaking right now may give you a few more years of service, but do keep an eye on them.
  7. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    Just bought a 2015 LB and still have my 2010 LB. "Normal" wear to suspension is gradual and often goes un-noticed. First thing I did notice after driving both cars however, was the struts/shocks need replacing on the 2010 with 95K miles. With a presumed bad rear shock at 78K on your 2010, I say replace all four. Sorry, these are not covered by warranty.
  8. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    Thanks all for your replies. I called around and found a reputable shop that will replace the two rear shocks for $314.89 out the door. Another shop quoted $450.00, and I still haven't heard from the dealer. I'll get both replaced, probably within the week.
  9. frodoz737
    4,795
    2,560
    33
    While I respect one's choice to repair their own vehicle or not, be advised shocks are about as easy as it gets when it comes to tools and skill. The info can be provided should you choose to save some money.
  10. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    Frodoz737 - I've been mulling around whether to do it myself or not. My brother-in-law is a mechanic, so that makes the choice a little easier. Can you provide any info, or were you speaking generally?
  11. frodoz737
    4,795
    2,560
    33
    I am that Brother-in-law in my families. If your's is willing, use him to assist as required using the attached...applicable to your 2010.
    PS - Use factory replacements only for the rears...unless you replace all four corners. I believe KYB makes after markets if you take the other option, but they likely cost more.
    hachislowku and peterjmc like this.
  12. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I would recommend doing all 4 also.. the rear are very easy to do where as the front are more time consuming.
  13. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    Thanks Frodoz737!
  14. cyclopathic
    3,292
    547
    2014 Prius c
    My fronts have 175K - no problem. Rears didn't need replacement and were replaced with better aftermarket. They were too stiff.
    Shocks do not go bad with time like cheese; there is usually a reason. It is pretty much pointless to replace shocks if the reason (bent rim, axle, unbalanced/bumped tire, etc) is not corrected.
  15. frodoz737
    4,795
    2,560
    33
    Not sure your point and I am not going to speak for your car, experience or tolerance but, shocks and struts do wear with "use". If an assumption is made that a shock/strut went bad "due to other damage", then you are correct, replacement should be accomplished after/during said repair and be replaced in pairs like wheel bearings, or all four if mileage/wisdom dictates. Changing and/or mixing shocks/struts for ride preference, brand loyalty, adding/changing sway bars, stiffeners, change ride height with springs or whatever are choices not related to this repair...and not Kermit262"s question. YMMV.
    PS - Your welcome Kermit.
    #15 frodoz737, Aug 19, 2015
  16. cyclopathic
    3,292
    547
    2014 Prius c
    I think we are not disagreeing. The point was that Toyota hadn't spec'ed out really crappy shocks so there is something else going on and it needs to be addressed prior to replacement - otherwise you are just wasting new shocks.
    Usually shock gets damaged if there is something with the wheel s.a. balance, out of round, bent rim etc, or by hitting a big pothole which isn't likely with rear wheel. He could have overloaded car. Or he could have hit a curb. Bad wheel or curb hit could damage hub, so it needs to be also checked. BTW Gen3 has rear hub assembly, which is ~$250+ (or it was a couple years back when I replaced it.
  17. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    Sorta like light bulbs, shock absorbers (and struts) die at unpredictable times, even if nothing else is wrong. They're considered normal wear items. On my last car, one strut failed at about 60K, and others went over 200K.
    hlunde and Kermit262 like this.
  18. frodoz737
    4,795
    2,560
    33
    That is why I stated, "If an assumption is made..." I can only recommend based on what is said and a picture that offers nothing other than what is stated. All questions were answered, reference material provided, cost savings submitted and recommendations made including to proceed with more qualified personnel available. Anything else is mere speculation requiring hands/eyes on.
  19. solrunner
    solrunner Member
    114
    37
    Reston, VA
    The Gen III has struts in the front and shocks in the rear. I wouldn't worry too much about a shock failing at 75,000 miles.
    If you are going to replace the shocks and also maybe the struts, you can go with KYB Excel-G which, from my understanding, is what Toyota installs in the factory. Someone correct me if I am wrong. The KYB are as close to OEM as you can get.
    You may want to consider installing premium shocks and struts. There is a thread on here about the Koni FSD, just search for that. Some say the ride quality is better than the OEM, and the handling improves. I have installed the Koni FSD struts myself, but I think I am having other suspension issues so I can't attest to the improvement in ride quality, but they definitely reduced the body lean when turning at high speeds. And I installed KYB shocks on the rear. If you want to get the Koni you have to buy all 4 (2 struts, 2 shocks).
    Like the other people are saying, it could just be that your shock wore out and failed. Or it could have been caused by a problem with the wheel, so you may want to have a mechanic inspect the wheel and see if it needs to be balanced or something is wrong with the tire.
    The newer Gen IIIs have little access panels in the rear to access the shock mount to make replacement quick. On your 2010 it does not have these so they have to rip out all the upholstery which is not hard but very time consuming. Another guy on here (in the Koni FSD thread) cut little holes and bought the plastic panels ahead of time make the job easier.
    Good luck!
    Kermit262 likes this.
  20. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    I didn't hit a curb, run over a pothole, overload the car, nothing. Very conservative driver. Just had the wheels rotated and balanced three days ago and no problems were noted. I suspect this shock just wore out.
