Leaking Water Inside of Car - HELP!
Discussion in 'Gen 2 Prius Main Forum' started by jbarbara321, Feb 11, 2013.
  1. jbarbara321
    jbarbara321 New Member
    I have a 2005 Prius and there is water coming into the drivers side floor. We believe this may have been going on for awhile and didn't realize it. My son drove the car and there was a "smell" that started about a year ago and I thought he spilled something inside the car.
    There was a lot of rain a month ago and the floor became drenched along with the back seat on the drivers side. Our mechanic saw nothing under the car and thought it was a leak in the windshield. We had the windshield replaced and cleaned out the cowl thinking that would fix it....still leaking. With the winter here, the gas lever freezes, the inside windshield is a sheet of ice and it STINKS!
    Before I bring it into Toyota and spend hundreds of dollars to have it diagnosed and fixed, anyone have any idea what could be causing this?
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    You might want to check the 12V battery compartment and the spare tire compartment. There have been reports of the hatch rubber seal leaking. Sounds like you a pretty bad leak somewhere. Someone may have driven it into high standing water also. Good luck.
    Edit: The smell at this point may also be associated with mold. This issue must be addressed immediately for health reasons.
  3. jbarbara321
    Thank you for the input. I believe the leak is coming from the front of the car and traveling back. My husband drives it now and he never would drive through high water. The car is parked outside and it will leak when it is raining and standing still.
    I am very worried about mold and plan on having the car detailed once we get to the bottom of this.
    52,812
    sit in the car and hit it with a hose nozzle until you find it. make sure you hit all the window edges, gaskets, seal, door handles and joints, seams, etc. all the best!
  5. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    if u hear some water sloshing somehwere in the front, it might be the space underneath the windshield cowl. either there a seal that leaks when the water travels down, or it's overflowing somehow to the passenger compartment. try and take it apart and check. there are instructions here on how to do it. search on how to install a strut bar.
  6. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Mold isn't going to be removed with a detailing. You're going to have to pull the carpets and padding out. You'll have to do this anyways to find and fix the source of the leak. It's an easy weekend project, just unbolt the seats and get to pullin'. Good luck!
  7. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I had a similar issue with my last car - a VW Passat. I found that it is relatively easy to dry out the carpet and padding - I would pull it by the doors and then shove towels in to mop up much of the water. Once mostly dry I'd then prop the carpet up to let the rest air dry. After it was dry I'd spray a ton of Lysol in and close it back up.
    As for figuring how the water is getting in, that is very tough. I'd recommend that you not bother with a hose - water coming at the car from strange angles and at pressure will just confuse things. You just need to become a sleuth and check the various spots where you could get leaks. Remember that just because you find water in one spot that its source could be on the other side of the car - a small trickle of water will run along a smooth surface so once it gets in, it can go many places. Also factor in the spot or spots that you park in if the are on a slope or even try a different spot and see what changes.
    On the very off-chance that you have an aftermarket sunroof look there first.
    After that I'd check the seals on the rear hatch and doors. If raining try running your finger or a paper towel around the inside of the seal to see if there is any water. It is likely a very small amount of water so you to only find a trace of it.
    I'd also check under the hood below the windshield - I have not had to deal with this on my Prius, but this is one of the spots that VW's have issues as leaves block the drain holes long the firewall - I guess that this could be the case with a Prius.
    Good luck.
  8. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    The drain to the HVAC is most likely clogged. If you put the car on a lift you will see on the passenger side a small hose coming out of just in front of the floor panel. That is the drain for the HVAC unit, using high pressure air
    blast that out and stand back as lots of water and other nasty stuff might flow out. You might have to do this a few times as it might re-clog. After all the water drains you might want to flush it out with lots of clear water. This you can do once. Make a mixture of 1/2 cup of bleach with 2 gallons of water, carefully pour this in through the cowl.
    This should get rid of the mold in the HVAC unit. The carpet, is a whole other problem. Once the intial problem is
    solve the carpet and pad will dry out, then have a detailer shampoo all the carpets.
  9. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    Hi all, hope I'm not breaking any rules posting here for the first time and bumping and old thread but I just got a Prius and found the problem. These are stress cracks in the seams of the hatch under the rear tail lights and under the rear apron behind the bumper. Hope this help fix the water in trunk of prius mystery. I wanted to add that I'll be using Napa auto branded seam sealer, some vise grip clamps and some blocks of wood to press everything back together.
    [​IMG][​IMG][​IMG][​IMG]
    SM-G935P ?
  10. bisco
    52,812
    welcome and well done, thanks!(y)
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Whatever you do never induce bleach into an ecoil. It will attack the coils and ruin the ecoil.
    Plus the car will reek of bleach. This is the the same thing as putting bleach in your home ac air handler. It ruins the coils and the house will reek.
    They make microbial coil safe cleaner on amazon.com called kooli to use on your ecoil. Comes with the rubber hose attachment that connects to the drip hose and injects cleaner back up the tube in the ecoil box.
    Same thing the dealer uses. Pleasant smell. Basic car maintenance. My dealer charges $125 for this service.
    Koolit is $15 a can,
    If your windshield dam is clogged take the wipers off and remove the cowl. You will see leaves and wet waste filling up the dam void. You will have to pull that out and then flush it out with soap and water.
    When the dam drain is clean you will see a Strong stream of water behind both front wheels. I check that every time I wash my Prius.
    A clogged dam is because you never open the hood and keep the dam clear of debris.
    PriFi likes this.
  12. ih8spm
    73
    29
    New York
    Thank you!
    SM-G935P ?
  13. ih8spm
    73
    29
    New York
    Well I finished my fix by using the seam sealer and forcing it in the cracks. I then used self drilling screws to pull the two seams together to prevent future separation and covered then with swam sealer. Since the cracks were behind the lights and bumper area it didn't matter how much sealer i used but I did smooth it out as much as possible with my finger and a latex glove. Left the lights on loosely overnight and the rubber seal around the trunk area out over night and wouldn't you know it was pouring rain for 6 hours last night. Well I was relieved to find only a few drops of water beeding on the trunk area. . The repair was a success. One thing I would recommend is that you remove the trunk rubber seal and clean all the area around it. This will prevent water build up which will cause premature wear of seals and welds. Hope this helps because this site gave me the confidence to take the PLUNGE into the Prius culture. [​IMG][​IMG]
    SM-G935P ?
