Leaky Intake Manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stephen Ross, Oct 13, 2022.
  1. Stephen Ross
    Stephen Ross Junior Member
    Lagunitas
    I
    After my 2014 Prius started presenting “check hybrid system” light repeatedly, especially after periods of battery stress (long periods of uphill driving, long idle times waiting for accident ahead to clear), my local Toyota dealership diagnosed the problem as a leaky intake manifold. My Dr Prius app also showed a P0A0F code when the light came on.
    There has also sudden swings in the hybrid battery charging (charges fast, discharges fast). The dealership says the battery seems ok. The battery is a warranty replacement battery that has 70K miles on it.
    Their price tag on manifold replacement is $1800 which seems a bit steep to me, particularly since I’m not getting any overt symptoms such as power loss or lower gas mileage. Also, why would the “check hybrid system” light come on for a manifold issue?
    Any feedback much appreciated…..
    Thanks,
    Stephen
  2. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    It's probably just he gasket... About $10. Fairly easy to do yourself with a few tools...
  3. Stephen Ross
    Lagunitas
    I
    Thanks, that would be the most ideal situation….
  4. Mendel Leisk
    42,342
    Just to clarify, Lagunitas is a city in the USA?
    So they're saying the intake manifold itself is cracked or compromised in some way, needs replacement? It's not just one of it's connections, a leak at a gasket or hose?
    Latest part number for the intake manifold is: 1712037054
    Suggested retail price: $315.91 USD
    Info from here:
    2012 Toyota Prius Hatchback Engine Intake Manifold. Exhaust - 1712037054 - Genuine Toyota Part
    I also see it (BC lower Mainland, west coast of Canada) for $222.28 CDN (plus $49.83 CDN for shipping), through Amayama:
    https://www.amayama.com/en/part/toyota/1712037054
    Here's my total price through Amayam, in CDN dollars, and converted to USD:
    Long story short, I could get that delivered, for $202 USD. Labour to swap intake manifold should not be more than one hour, say $100 USD. Heck, I could do it in under an hour.
    Bottom line, if they're just swapping an intake manifold, $1800 is about a grand over-charge. About the usual...
    If you're interested in DIY, it's not that hard to do this.
    Step one though, would be to verify it's leaking. I think you could test if you were to remove it, tightly seal the intake ports, pcv, evap throttle body and MAP sensor openings, then apply vacuum to one port (say the pcv or evap). If it doesn't lose vacuum they're barking up the wrong tree.
    Attached Repair Manual excerpt has info on remove/install of intake manifold, torque values for example. Also, watch @NutzAboutBolts intake manifold cleaning video. It's linked in a thread pinned at top of this forum.
    #4 Mendel Leisk, Oct 13, 2022
  5. Mendel Leisk
    42,342
    Dealership would replace all gaskets, which would add about $50~60 USD, still a wee bit short of their quote.
  6. Stephen Ross
    Lagunitas
    I
  7. Stephen Ross
    Lagunitas
    I
    Correction: not ECU but ECM, though after Google search 8966047752 is not listed, probably it’s 8966047751
  8. Stephen Ross
    Lagunitas
    I
  9. bisco
    52,841
    how many miles on her?
  10. Stephen Ross
    Lagunitas
    I
    218,000, the engine was replaced by a used one at 210K….it had about 60K on it at the time…
