Leaky Struts. How urgent to replace?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by wwthedubww, Jun 16, 2023.
  1. wwthedubww
    wwthedubww New Member
    SoCal
    2019 Prius
    Hi y'all. First time posting. Recently had 3 tires replaced and upon completion told I had leaky struts that needed replaced. 2019 Prius, 50k miles. Will attach 2 pics. Any insight, from the attached pics, the level of urgency I might need to replace these struts. Thanks in advance :) dbb38bfa-7333-46df-b24a-5c9b994ba30e.jpg 667af7d7-c957-49ea-b32a-0fa122dd8b99.jpg
  2. Doug McC
    Doug McC Senior Member
    1,084
    424
    Midwest
    2022 Prius
    I can’t remember the name of the video but The Car Care Nut addressed this in one of his YouTube videos shortly after opening his new shop. Maybe someone here recalls more.
    Having said that, I don’t see any leakage. In fact they look pretty good.
    wwthedubww likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The urgency is with finding a different tire shop that will not try to SCAM you into replacing
    high-dollar items that are perfectly fine. :mad:
    Get a second opinion.
    wwthedubww, Montgomery and Doug McC like this.
  4. Leadfoot J. McCoalroller
    8,157
    7,660
    Pennsylvania
    2018 Prius c
    Not urgent at all, especially if it took this long to hit 50k on a 2019.
    Might be more urgent to find a better repair shop.
  5. SSAutomotive
    SSAutomotive Junior Member
    Stewartstown, PA
    I'd suggest within a year and a half maximum.
    Worn struts/shocks lead to increased tire wear as well as higher speed handling issues on bumpy roads. This isn't a scam. This is real physics. Once these units go really bad, you'll likely see tire cupping, and depending on how new your tires are, I wouldn't push too far on that line. Question is, how long before that threshhold is hit. Based on the photos it seems to be a weep, but once that seal starts to go, as I said, how long before unit failure. Time to save up if you haven't already. Good luck.
