Lean/swerving at high speed/freeway?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by stackcheese, Aug 12, 2012.
  1. stackcheese
    stackcheese Junior Member
    50
    Pasadena, CA
    Hello all
    recently purchased the PIP, yesturday in fact, and while driving on the free way home the PIP felt weird/unpleasant while changing lanes on the freeway.
    Not really a car enthusiast, but coming from a V6 Honda Accord, the prius felt really/tall/lenghty as while changing lanes at high speeds the car felt like as if the top wanted to go one way and the bottom wanted to go another.
    To combat this would it be best to get some kind of sway bars?
    Strut bars? Springs? Coilovers? Once again i'm not a car enthusiast, but would prefer to have my drive smoother/less swervy/tipping.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Air up your tires to either 44/42psi, 42/40psi or 40/38psi. This will help the car feel more stable.
    stackcheese likes this.
  3. stackcheese
    50
    Pasadena, CA
    ill give it a try once the battery is done charging ^__^
    sway/strut bars aren't what i'm looking for?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. Mike500
    Mike500 Senior Member
    2,593
    767
    The driver's feeling of "lean and swerving" has nothing to do with the actual vehicle but the "feedback" which the car gives you as the driver. You are NOT the first to notice this effect. There is along history with this issue and previous and current Prius models.
    In aircraft design nomenclature, this is called "airframe or control flutter." That's why aircraft builders have test pilots. The design and flying characteristics of a vehicle itself might be absolutely stable and performing perfectly, but if it doesn't feel right, the pilot will react to the "flutter" as he or she would to a real situation.
    When I took my 2012 Prius"v," I felt an uneasy feeling, like I've felt on a vehicle, when it reaches the threshhold limitation of understeer and goes to oversteer.
    After I installed a custom "box beam" center chassis brace that I designed, the flutter that caused this disconcerting "phanton" feedback that mimics loss of control, is gone.
    Toyota, in early 2012 quiely, and without formal announcement, introduced a stillfer but "torsionally" flexible mid-chassis brace made of 5 steel pieces with 7 welds. While this has increased the "feel" of greater stability, I developed an even "stiffer" brace with the same torsional as Toyota's new one. It is a "one piece"box beam" that weighs at least one pound lest than the new Toyota model, with the same weight load as the earlier "thin flexible one." There are quite a few Priuschat users, who have successfully tested the NEW brace and are VERY satisfied.
    wiggleman likes this.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The OP has a PIP not a v.
    The Prius sways quite a bit from the factory but adding air pressure to your tires helps stabilize the car a little. A rear sway bar can help but the main effect is to flatten cornering. I've found that 17" wheels and lowering springs make the largest impact on handlingand freeway stability. The wheels make the largest impact but negatively affect mpg and EV range.
    JimboPalmer likes this.
  7. Mike500
    2,593
    767
    The chassis of both cars are basically the same and share a lot of the suspension components.
    The modifications that you propose will definitely change the performance parameters of the chassis. My findings are for relatively "inexpensive" easy "bolt-on" modifications that improve ride "feel" without creating a harsher ride.
    Basically, I have found the standard chassis to be quite good on the freeway. The rails of the exhaust system tunnel, however, is lke an open tube on the bottom that "opens and closes." The effect is that the driver feels the flex, when the wheels are actually really well planted on the road. Eliminating the flex effectively eliminates the driver's feeling of unstability.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I can feel another BT Brace argument coming on..... Same stuff 7yrs later. :)
  9. Mike500
    2,593
    767
    The BT was a good start. In early 2012, Toyota upgraded the brace to a 5 piece design with 7 weld joints. Toyota engineers evidently adopted the complicated design to achieve stiffness to eliminate the sideway movement of the exhaust system rails. They did not just adopt a thckened plate, because they recognized that the brace formed an "H" shaped structure with the right and left rail. These rails must move in a scissors like fashion. A steel tube, as used by Toyota, allows their brace to twist with very little resistance, while still being stiff and hard to bend.
    I went back to the history of the early days of Orville and Wilbur Wright, since I am a history buff of the dawn of aviation. The Wrights discovered their invention of a principle they called "helical torsion," when they saw how a rectangular cardboard slide on cover to a bicycle inner tube box twisted with very little resistance. They also noticed, that if they firmly held the ends of the cover, how stiff it was to bemding. The later called this principle "wing warping" and used it to control their first airplanes.
    I one can picture the "H" shape with its long arms, it would be redily clear that, if the cross member of the "H" was very resistant to "twisting" like the original BT plate, the up and down thrashing of the free ends of the "H" represented by the four tires would exert enormous stress on the joints of the brace. That would effectively and eventually repeatedly bend the joint back and forth like bending the ends of a paper clip. The result would be cracking of the joint from the separation of the crystals in the metal.
    So, BT was a good start. But, it has "unintended consequences."
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I was wrong, no idea how I made that mistake.
  11. Net Junky
    Net Junky Junior Member
    38
    it may be just me, but from experience with other cars the feeling is all about the alignment. The prius is aligned to give the most MPG but gives up on freeway stability and steering feedback. From experience on my sport cars, changing toe and camber can help stabilize the car at freeway speeds, but it could also hurt MPG. Just need to consider the compromises. Also changing tire pressure to give the car more neutral feel.
  12. stackcheese
    50
    Pasadena, CA
    does 44/42psi mean 44 front and 42 rear?
    you'd want the rear to give a little more due to the battery? is this proven or just assumptions considering the front of the car is where the engine is? or is it a little less in the rear due to it being front wheel driven?
    also does the prius have some kind of pressure guage? or do i have to use the guage at the gas station air pump?
    thanks
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The split pressure is recommended by Toyota. Look in your door jamb on the placard. Toyota calls for 35/33psi front/rear. Unless the PIP is different in which case I would follow that specific recommendation but with higher pressure.
  14. bisco
    52,758
    buy a decent gauge at an auto parts store, sears, etc.
  15. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Costco has free hydrogen pumps that regulate pressure. Pull up, set the pressure, and fill up.
    I have found that the wobbling has gone away after 4000 miles. Or I have gotten used to it.
  16. Net Junky
    38
    only if i had a Costco membership....
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Don't put hydrogen in your tires. Hydrogen mixed with the residual air in the tires would be a potentially explosive mixture. It will also leak out much faster than air.
  18. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    You dont need one. The compressor is outside the garage.
    And hell, maybe its nitrogen. I am not a scientist and am not standing in front of the pump. I do remember that it was not a typical air compressor.
  19. ralteredstates
    ralteredstates Junior Member
    24
    coastal Connecticut
    Yes it's nitrogen. I believe hydrogen would give our tires way too much pep.
  20. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    With over 5K miles on mine, I'm also feeling less of what I call "wandering" due to the grooves cut into the pavement on some of our L.A. area freeways. I don't notice anything unusual when changing lanes. I started out running my tires at 40/38, but am gradually letting them drop naturally to find the most comfortable and stable pressure. My usual practice is to check and air them up twice a month, so now they are down a couple of pounds and that may be helping. On smooth pavement without the grooves, the car has a very comfortable and smooth ride, without any wandering at all.
