Leave On or Turn Off?
Discussion in 'Gen 3 Prius Main Forum' started by markabele, Jul 12, 2012.
  1. Dorian7
    Dorian7 Junior Member
    70
    16
    That makes sense. I know my girlfriends Sentra turns off if the FOB leaves after a certain amount of time. It will be interesting to see what happens when it does go dead. Haha.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    I did not know that.
    In this region it is a very common during winter to see half [or more] vehicles parked in a grocery store lot were left running to keep them warm.
  3. Brett.
    Brett. Junior Member
    134
    26
    I've read several people claim that warm up stages can be avoided by leaving the vehicle on "ready" when exiting for a short period of time. However from my observations it's summer time right now, and the ambient air temps combined with even the shortest of drives leaves my engine warm enough that I've taken the car 7 miles to the store, shut it off.. come back out 15 minutes later and it did not run through the stages. The coolant / cat were warm enough not to require the ICE to turn on. It really could be graphed out as to how long you have before the ICE will run itself again, but 5 minutes on a hot day shouldn't require the startup sequence unless you only drove a couple of miles before shutting the car off. The further you drive before shutting it off, the longer you should have (in theory) before it will start up.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    On hot days, I regularly leave my Gen2 turned on while I go shopping. Just use the mechanical key to lock/unlock the door. The engine cycles ON/OFF as required to operate the electric air conditioning.
  5. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    Luckily there is the anti-pinch system for the window.
    mad-dog-one likes this.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In the 2012 there is an item in the setup menu that aloes you to turn off/on the SKS system. Is this similar to the old push button under the dash on the GenII?
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I'll take your word for it.
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    With the Gen III and SKS- if you don't want to use the auto up window method.... you can start car normally, leave it running- get out with the fob, using the metal key built into the fob- manually lock the drivers door- this will lock the other doors/hatch. Run your errand- use the manual key to unlock the drivers door- get in, all is back to normal.
    FWIW- for those looking to keep the cabin cool on hot days while ducking into the 7-Eleven/Pizza shop, etc... - I've been able to run the AC for 20-23min at 76deg with the fan on two bars without the ICE kicking in. My hybrid battery is usually 2 bars from the top and I turn off the DRL's.
    ForestBeekeeper likes this.
  9. markabele
    5,084
    1,782
    Nebraska
    I would suggest that if someone is really set on leaving their A/C running to keep the car cool, at least put it up to 80 during that whole time.
  10. ForestBeekeeper
    779
    308
    Maine
    It rarely gets over 80F in this area anyway. We routinely see vehicles left running to keep them warm.
