Leaving a cooler of ice in the Prius for hot weather.
Discussion in 'Gen 3 Prius Main Forum' started by Pijoto, Aug 30, 2016.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I am impressed it is up to 80+ posts personally
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My contention/opinion is any "coolness" created by this type of action is going to be minimal to the point of near non-existence.
    How leaving a open cooler with melting ice could make the vehicle "drier" is an act of physics beyond my understanding.
    If anything leaks or the cooler get's knocked over, it's going to be a lot wetter.
    I think it's a bad idea. Nearly useless action.
    51,950
    maybe a brick, in the bottom of the tipsy cooler, to keep it stationary in the parked car.
    Fred_H and Raytheeagle like this.
  4. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    You never know when the occasional side winder, earthquake or hurricane will come by and tip over your cooler:(. Or is that something else to frivolously worry about:whistle:.
    Pijoto, Fred_H and bisco like this.
  5. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    Where do you think the condensation water on the outside of a sealed bottle comes from?
  6. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    & where would the water from the melted ice evaporate to?
    in the end the humidity in the car will be higher/
    The Electric Me and Raytheeagle like this.
  7. bisco
    51,950
    unless the bottles are sealed.
  8. StarCaller
    1,277
    729
    5 pages for that/
    I'm out of here....//
  9. bisco
    51,950
    really? we're just getting started.:cool:
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Your attempts at logic and reason were valiant, however we'll see if we can get to page #6 talking about frozen water and negligible temperature decline in a hot and humid area:D.
  11. bisco
    51,950
    hey, why not? it's working over in the galaxy thread.
  12. BZzap!
    BZzap! Senior Member
    1,607
    878
    On the other hand, what do you think about putting a box of hot rocks in you car to keep the windows from icing up in the dead of winter?
  13. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    BTDT said the PIP owners.
  14. bisco
    51,950
    hmmm, you may be on to something...
  15. BZzap!
    1,607
    878
    Flat, slick, slimy river bottom rocks rule!!!
  16. Pijoto
    Pijoto Active Member
    200
    153
    Dallas, TX
    So I tested it over a couple hours, I was able to reduce the cabin temps by 1-2 degrees... Success :cool:
  17. bisco
    51,950
    victory!!!(y) wisdom is judged by her children.;)
    Pijoto likes this.
  18. qdllc
    qdllc Senior Member
    1,377
    400
    I don't think the heat (even in Texas) is bad enough when the vehicle is parked to damage the battery pack. The key thing would be to let out the heat as soon as you open the door (lower all windows). This way, the interior will cool down sooner. It's the charging/discharging of the pack that bumps up the heat and demands cooling.
    Tbkilb01 and Pijoto like this.
  19. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Somewhat true, but if the car is parked in full sun on a hot day, the battery temperature climbs well above ambient air. Therefore it already has a big head start toward alarming temperatures if you then drive it, with all the charging and discharging that implies.
  20. BZzap!
    1,607
    878
