Leaving car "on" unattended, but secure?
Discussion in 'Prius v Technical Discussion' started by Onlooker, Apr 26, 2019.
  1. Onlooker
    Onlooker Junior Member
    37
    Nova Scotia
    2014 Prius v wagon
    Technology
    I wrote one maker of a remote start to see if the auto-off can be changed/disabled; Will try the others that I can find. I also wonder if a wired switch could be installed in place of a remote starter, to leave car 'ready'/AC-heat on and require a cycle and key to actually drive away. Depends what sort of communications are relayed with the remote starter and cars computer.
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    I just checked with my son. He got Remote Air Conditioning.
    In 2015 it was packaged with remote start. He thought some years it was a separate option.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Don't forget to connect in the radio!
  4. Onlooker
    37
    Nova Scotia
    2014 Prius v wagon
    Technology
    Update:
    Q/A with seller suggests this model can be reprogrammed to stay on indefinitely; The hardware/software needed to do this seems to be $50 more(
    Looking up the kit's contents suggest the real meat/brains of the device is $50 part which you might be able to largely bypass the 'remote start kit'.
    Toyota Prius V 2014 Push-to-Start | Remote starter, bypass module and alarm system | Fortin
    Fortin - EVO-ALL - Universal All-In-One CAN Bus Data Interface And Transponder | eBay
    On the plus side, while someone could still technically break and climb through a window, and start driving; Apparently using the brakes kills it also; not going to get very far w/o brakes... I wonder if 'power steering' use could be set to power car down also... ;p
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    It looks like a repackaged Viper system. All of these are wired into the car's network (CAN Bus) and have to include vehicle specific firmware/software in order to emulate the factory remote start. It's interesting the Viper version with the "T Cable" is actually less than the equivalent MPC knockoff. Of course MPC is selling self install instructions where Viper requires a professional installer which would add labor. Overall these are almost identical solutions except MPC has preloaded Prius v compatible software while the Viper version requires the certified installer to load the firmware. viper vs mpc remote start.jpg
