Leaving Headlights On and EV Range?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jun 11, 2013.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I'm trying to figure out the effect on EV range of leaving my headlight switch in the On position.
    This was in another thread:
    Is the 110 watts figure for the Basic headlights, or for my Advanced LED headlights? What's (watts?) the figure for the other type of headlight?
    (I get more like 11 miles on a 2.7 kWh charge, or 245 Wh per mile.)
    I'm asking because California and 18 other states require headlights to be on when wipers are on, so the simplest solution would be to just leave the headlight switch in On all the time (or at least from September to April when it rains here).
    Edit: Power consumption of lamps is in this post.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Regular halogen headlights are 55 Watts each.
    The LED headlights are more efficient. If I recall, they are 35-40 Watts each.
  3. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Thanks. I'm surprised; that's not nearly the percentage reduction from a home incandescent bulb to an equivalent LED.
    Does anyone know the total power consumption when the headlight switch is turned on? Headlights plus any rear or other lights?
    52,751
    a drop in the ev range bucket.:p
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    If you have an OBDII device, you can log the PHV battery amp. The amp drawn includes the load of the power inverter and all the accessories and may be able to figure out the difference between the lights on/off.
    I have monitored it before and it didn't make a difference to tell in realtime. However, with data logging and creating charts with average values, you may be able to detect the difference in amp drawn.
  6. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I can confirm that one, on my base, I never saw any impact on my range, and I did plenty of testing.
  7. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Are you not using daytime running lights? If so, then AUTO mode will always have at least DRL on which satisfies the requirement, IMO.
  8. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Let's say it takes you 20 minutes to use up your whole EV range of 2.7 kwh. during that time if you were using 120 watts for lights it would be 40 watt-hours. That's 40 out of 2700 or 1.5%. No big deal so don't worry about it.
    (But I still have all my lights off except when needed or required by law)
    Mike
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Whenever I don't have my halogen headlights on, I always have my DRL LED light on. It is where the fog light is and I like to be seen with it on.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    DRL does not satisfy the headlights-with-windshield-wiper law, at least in California (can't speak to other states' laws). One reason is that the other lights, such as the taillights, are not on with the DRL. Our local newspaper traffic reporter pointed this out recently.
    And as an aside, none of this applies to Canada, where the DRL is part of the headlights, and cannot be turned off.
  11. DLee
    DLee Junior Member
    81
    I wonder how many tons of Carbon Dioxide are generated in the US every year by daytime driving lights? I bet it is significant.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't know if this is true but I also drive with DRL's with parking lights in the rain so that the whole car is illuminated. I plan to feign ignorance should I be pulled over. The intent of the law is so you are more visible and the DRL's do that.
  13. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I replaced my bulbs with LED' s 20W /each
    They don't light up the road much (if at all) but are visible and save energy on my "V".
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    If you assume 100M cars driving one hour each during daylight and 100 watts, that is about 10M kwh (10B wh).
    Roughly 500 - 1000 grams of CO2 per kwh, depending on the fuel source (800 for oil, 500 for NG to PIP, 900 for coal, 8 for nuclear, 4 for hydro...plus charging losses). So, going with oil it is 8000 metric tons/day (1 ton = 1M grams) or ~3M tons/yr. In 2008 the US emitted 5461M tons. Hmm. 3M tons seems high. Maybe a math error somewhere.
    Mike
  15. Tideland Prius
    16,665
    The problem is that there isn't just one LED in each bulb casing. There's a cluster IIRC. And you have two clusters per side of the car. At least the LED floodlight is gone in the 2012+ models so Toyota has found a way to illuminate near/wide without the use of a 3rd LED floodlight found on the 2010/2011 model with LED headlights. (and one cluster down from the LS600h L's set).
  16. ryogajyc
    985
    165
    Reseda, CA
    Where did reporter get that from? While I agree taillights increase visibility, the actual vehicle code only requires two lighted headlamps:
    V C Section 24400 Headlamps on Motor Vehicles
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Normally, DRL runs at about 1/3 power of normal headlights.
    My DRL is LED bulbs so it should be about 20 watts. I believe there is safety in the ability to see and also be seen (easily). I can live with 20 watts for that safety feature.
  18. CharlesH
    2,798
    1,166
    Roseville, CA
    Right, and apparently, DRLs are not "headlamps". "Headlamp" does not equal "light bulb". The legal definition(in some federal standard, I believe) involves, along with other things, casting a focused beam a certain distance with a certain intensity, which DRLs don't satisfy. Sorry, I can't come up with citations at right now.
  19. Tideland Prius
    16,665
    They can be up to 80% intensity. They're not usually 1/3rd power (that's too dim).
  20. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Torque shows me two battery current values: Batt Pack Current Val (Bty Curr) and Power Resource IB (IB. Both of them seem to display the propulsion pack current.
    I assume the lamps are driven off the 12v system, right? Is there a parameter for that current draw?
