LED-backed Lower Rear Red Reflectors
Discussion in 'Prius v Accessories and Modifications' started by Air_Boss, Jul 4, 2014.
  1. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    I conclude the backfeed is internal to the LED-backed lower rear reflectors, from low (white) to high (red).
  2. Air_Boss
    4,248
    1,195
    New Yawk
    This was no muss, no fuss. Connected up with 24 awg Posi-taps. Thanks for the pictorial!
  3. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Do you have to remove the lens's cover from underneath or you can just pry off the stock lens from the outside because I saw the clips on the kit that I bought, which look like it can be pushed in to lock?
    Thanks,
  4. Air_Boss
    4,248
    1,195
    New Yawk
    One retaining screw in center of back of bezel (rear of bumper cover, from beneath), the two friction clips are for secondary retention and location.
    tanasit likes this.
  5. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Thanks for super fast reply.:)
  6. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Just installed mine yesterday connecting both parking and brake lights, NO third brake light glow as seen below (y):
    I am not sure if you have a short circuit somewhere but I cut a notch where the wires passes under the weather strip to relief the pressure and taped up the wires at that spot for extra protection as seen below:
  7. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I was going to say that having wires against bare sheet metal edges looks like a short circuit waiting to happen.
    SCH-I535
  8. Air_Boss
    4,248
    1,195
    New Yawk
    True, though the metal edges are formed and painted, not sharp -- until cut by the Dremel tool.
  9. tanasit
    tanasit Member
    399
    60
    Philadelphia
    That's why I used Super Tough 3M tape over that spot after I rounded off the sharp edges with a jewelry file. ;)
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There's always going to be a certain amout of movement and rubbing involved in a situation like that. It WILL short, sooner or later.
    I'd be drilling a hole and using a rubber grommet.
    xliderider likes this.
  11. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Tight fit and fully seated inside the weather strip? Time will tell.:unsure:
  12. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Every time the gate opens or closes, every time you hit a bump, hot/cold cycles....... lots of movement.
    Check it in a few months, you'll the tape wearing away.
  13. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Good reasons, so I will report back in a few months.(y)
    Thanks,
  14. Air_Boss
    4,248
    1,195
    New Yawk
    FWIW, I went back and connected the stop lamp function. Works fine and get no current bleed into the CHMSL.
    Brake lamp conspicuity greatly improved, day and night.
  15. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I "need" these lights - as parking lights only.
    PRICE??
  16. Air_Boss
    4,248
    1,195
    New Yawk
    Including shipping
    From SHARE+STYLE via Rakuten, including shipping, $62, though that was when the Yen was higher. I'd estimate $60 today.
  17. gmdog2
    gmdog2 Junior Member
    Augusta, MI
    Nice convo, great information..thx to all involved..Ordering today..
    nice
  18. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Just ordered these yesterday.
    I'm doing it for the added safety. Las Vegas is a 24 hour drinking and drugs town and every little bit of illumination helps.
    I'll hook them up as "parking lights", not as brake lights.
  19. Air_Boss
    4,248
    1,195
    New Yawk
    You know they can be both, right? They are a three wire, dual density LED array.
  20. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I may have my local custom shop do the install for making them dual purpose lights IF indeed they don't reduce the normal brake light brightness.
