LED Daytime lights, best wiring option?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mkarolian, Jul 8, 2014.
  1. mkarolian
    mkarolian Junior Member
    56
    Boston, MA
    I picked up a set of these LED light strips on Amazon (surprisingly well reviewed) and I'd like them to power on anytime the car is on.
    One solution I thought might be viable using one of these "add a circuit" type deals. Opinions on this? There is a red lead coming off of the add a circuit, but I'm not sure where I'd need to connect the negative wiring.
  2. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Yes, use an add a circuit, you just need to find a circuit that is only hot when in Ready mode. The negative side of the wiring can be any good ground, like a bolt on the body or fender.
    SCH-I535
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    You should have someone do this for you!
  4. Steve Holmes
    Steve Holmes Junior Member
    UK
    I fitted my front DRLs (eBay from Hong Kong) in the grill and the nearest 'ready' power point was the washer motor some 12" away.
    Just unplug the connector from the washer bottle (near the bottom) and scotchlock the positive to the blue wire. The negative goes to the chassis bolt nearer the front.
