Led DRL DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by spiderman, Jan 8, 2011.
  1. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    also --- I'm assuming that's the XENON WHITE color you ordered, correct? (looks like 6000K)
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^Yes, xenon white.
  3. Tideland Prius
    16,674
    well those without foglights can use the foglight area to house some LED strips.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ True. I was looking at those replacement LED turn signals with DRLs but after seeing how much they cost, I lost interest.
  5. isteve74
    isteve74 New Member
    Fullerton, ca
    Nice Job.. looks great
  6. carl brett
    carl brett New Member
    Orlando
    Spiderman-Looks great! What was involved in activating the built in LEDs at the top of the headlights? Thanks for your help!
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hi Carl,
    Ah those dimples in the headlight are not LEDs... just decoration. Some on the forum have removed the lens (you have to bake it off) and replaced them with actual LEDs. I didn't want to do that.
    I did replace my parking/marker light with an LED bulb however. The W5W bulb just fit in because it was rather tall.
  8. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Nice job - it looks really good. Too bad that in the EU if you do something like this you need to get it approved by the traffic authorities or risk getting pulled over for driving a non-EU conform car with non approved lighting....
    Regarding pic 1 - now I know why the windshield wiper fluid storage would take so much of it and why it can freeze in winter - it is exactly behind the bumper (where else??) and far from the engine (that runs pretty cool in any case...).
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thank you.
    Yes, that is what Paja mentioned too. Too bad, sounds very restrictive over there. To be honest there are many rules over here too but are not actively enforced. In fact someone mentioned that HIDs where not allowed here (Alaska) but I would say about 50% of the cars have them.
  10. bagwell
    592
    49
    the woodlands, tx
    just a warning....if you really had to push W5W bulb in there and its making contact with the inside of the clear part of the headlight, the heat from the LED bulb may damage it....trust me I know!!
    I used something like this..
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ The bulb is very close to the lens but I think there is still a small gap. I will keep an eye on it though, thanks. What happened in your case?
  12. bagwell
    592
    49
    the woodlands, tx
    it appears as though inside the lens is oozing some type of oily residue as a result of the heat buildup.
  13. bagwell
    592
    49
    the woodlands, tx
    installed the same LED DRLs today.....
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Dude, the link is broken. Glad you got them installed. How far did you wrap them around the side??
    Edit... the link works now. Looks grand.
  15. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    I think if we install the DRL LEDs inside headlamp housing, no body will find it as illegal. The bad thing is the voiding of the warranty for headlights. The dissasembly of HL housing with so complicated curved shape (oven method) will not be w/o risk. Headlamps are quite expensive parts to test it :(. I didn't notice any guide for successfull Prius HL disassembly yet.
  16. bagwell
    592
    49
    the woodlands, tx
    from my iphone 3GS
  17. FEINT
    FEINT New Member
    22
    Japan
    Is this install possible without removing the bumper? Those look mighty awesome!
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Unless you can remove the headlight housing without the removing the skin... It appeared that might be possible but I didn't bother determining that when I had the skin off. Should have I guess.
    Thanks!
  19. bagwell
    592
    49
    the woodlands, tx
    I didnt remove the bumper, just loosened each side enough to clean under the headlight and install the LED strip.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ perhaps you could provide detailed instructions on that?
