LED Headlight Bulbs Okay?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by sejinro, Jun 11, 2017.
  1. sejinro
    sejinro Junior Member
    23
    Los Angeles
    2014 Prius Plug-in
    I have a 2014 PIP Advanced but it does not have the LED headlights. Will something like this work for my car? I believe my car does have the projector lens, but halogen bulbs. Looking for a brighter look.
  2. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Only the low beams (and DRLs) are LED, at least on my 2012 PiP.
    KCobby likes this.
  3. KCobby
    KCobby Member
    229
    74
    NYC area
    Your car should have LEDs for low beams and DRLs as @galide says. Did someone swap them out for halogens at some point?
  4. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    The 2014 PIP Advanced did not come with LEDs as a standard option. It was for the 2012 and 2013. I have the regular projector halogen lamps that are found on the base.
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    HID bulbs will be more efficient (less watts for similar output) and have better beam pattern and throw than LED bulbs. In addition, you can select the color temperature of HID bulbs where that option really isn't available with LED bulbs.
    I'm very happy with 4300K HID (oem on many vehicles), bright white with no blue.
  6. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    How do the 4300K compare to stock?
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Much brighter and whiter than stock. 4300K HID looks pure white and is about 3x brighter than oem H11 Halogen, which looks yellowish.
  8. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Cool thanks
  9. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    Any recs on HID setups for the 2014 PiP? As well as installers in the Los Angeles area?
