LED Headlight Conversion Kit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ScudderWoods12, Jan 12, 2018.
  1. ScudderWoods12
    ScudderWoods12 Junior Member
    Snohomish Washington
    I have not seen any new content on this topic so I wanted to see if anyone had some suggestions.
    I want to get the xenon LED conversion kit for my 2012 Prius. Is it worth it? How well does it work?
    Anyone have any thoughts on what LED conversion kit to get?
    Thanks!
  2. ScudderWoods12
    This is also for low beam headlights.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    There are a lot of threads on the topic of headlight upgrades. I know because it's always been one of my favorite topics. I love the satisfaction of a thick spread of light with a clean cutoff.
    There are a number of plug-n-play options for LEDs and HIDs which are easy to install and don't cost very much. Unfortunately, you're never going to get a deeply satisfying upgrade without a some custom work. On top of that, there are a lot of folks that would be happy to flame you for installing a plug-n-play kit which will blind oncoming traffic when used in projector designed for halogen bulbs.
    Montgomery likes this.
  4. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    Over the last 2 years I have tried a few of the plug and play kits.
    The HID kits have terrible dark spots and so actually give less useable light that a halogen bulb.
    The LED weren’t much better than the HID but had the added annoyance of a whirring fan on each bulb that in the end made as much noise as a refrigerator unit on a truck!!
    Both look good when viewed from the front but performed badly, I ended up buying some high quality performance halogen bulbs that appear to give a greater spread of light.
    2010 Gen 3
    Robert Holt and Dylan Doxey like this.
  5. torparts
    torparts Senior Member
    417
    643
    Compton
    Any suggestions on bulbs that you speak of... I agree with you regarding the kits you mentioned .... but oem bulbs are just horrible
  6. Jayw13702
    142
    170
    Plymouth UK
    Are you uk or us based?
    2010 Gen 3
  7. Boise Jim
    Boise Jim Junior Member
    16
    Boise, Idaho
    I'm still scratching my head why people think the OEM bulbs are so bad. Mine perform very well, but I also keep my lights looking like new.
  8. torparts
    417
    643
    Compton
    Us based
    It’s probably a perspective thing... prior car had led headlights and where we live tends to still considerable amount of city lights....
  9. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    I just got this late last year. Nice clean cutoff
    No noisy fan to fail. just don't touch the heatsink after u had it running. Had one set DOA for another car, vendor send out new set after sending claim and pix.
    PokerMunkee and mikes951 like this.
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Resistor comes with kit?
  11. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    Resistor? I thought that was only needed for turn signal. This is just plug n play.
    Nima psn and Grit like this.
  12. 04priusnow
    04priusnow Active Member
    345
    201
    some cars will show an alarm if the current draw of the headlight is to low.. they use resistors to trick the system and prevent codes
    PH-1 ?
  13. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    No issue so far since october.
    Nima psn and PokerMunkee like this.
  14. Marrico
    Marrico Junior Member
    US
    Will I have low and high beam operation?
    How hard is it to install the resistor?
    Would I be better off getting a kit that has the conversion to trick system built in?
    Any other plug n play suggestions for low and high beams fully plug n play?
  15. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    Just bought those Beamtechs. Should get them on Wednesday. I'll update thread with thoughts and pics once installed! The halogens in my 2011 suck! Plus I hate the boring yellow look, all my other lights have been converted to white LEDs.
    I'm going to leave my high beams a lone, they work fine and I don't use them often. I just want low beams to be LED.
    Grit and RMB like this.
  16. Mr. Prius
    Mr. Prius Junior Member
    82
    24
    Installed the Beamtechs yesterday. Love them! Major improvement. Paid $36.99. Were LEDs much more expensive a few years ago? I put in new headlight assembly units last month which has made the car much younger-looking and the road is so much brighter now with these LEDs. Noticed a parking light was burned out during my install yest and so I’m going shopping again on Amazon.
    write2toonces, RMB and PokerMunkee like this.
  17. tuskin
    tuskin Member
    51
    51
    SFV CA
    check your PM. Thx
  18. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    just don't touch them after usage. The heatsink is super hot.
  19. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    No need for resistor. Its plug and play.
  20. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Even side turn signals in front headlights?
