LED Headlight Conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by genetiix, Sep 3, 2012.
  1. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    I've always had an interest in headlights and did several hid retros back when hidforum was still around (before hidplanet).
    I purchased a base PIP back in March cause I couldn't justify the higher premium of the advanced model. As one of my first mods, I purchase a hid kit however found that the beam pattern and colors were very disappointing. I ordered 4100k but looks more like 6k. Also, with the kit, the OEM projector's beam pattern had a weird step to the sides and the throw of the lights were splotchy. I guess it was my fault for going cheap with the kit to begin with.
    Right after this, I decided to no longer spend money on kits and upgrade my headlights; Either do a hid retro or LED conversion. I got a great deal on one of my LED headlights and for the next couple months, I slowly gathered all the parts required to make it all happen.
    Below is my completed project... I do lack auto leveling however, if I went with a retro I wouldn't have it either. In addition I live in California and don't have a need for the headlight washers. I tried to take progress pics however didn't get as many as I liked. I have a couple more.. But these are the best..! Enjoy.
  2. peterjmc
    908
    185
    Clarksburg, MD
    The lights look great!!
  3. F8L
    19,011
    4,063
    50
    Grass Valley, CA.
    Very cool!
    Could you do a quick write up that details some of the major parts that needed changing or adapting?
  4. Plus IV
    Plus IV LowGen4
    451
    394
    Ladera Ranch, Ca
    Four Touring
    I think the LED headlights are around $750/each. Am I correct on that?
  5. peterjmc
    908
    185
    Clarksburg, MD
    That's about right for full retail cost. You need to purchase the OEM housing plus the LED control box. They total to around $750.
    If you're patient and resourceful... you could probably source the pieces for significantly less.
  6. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    peterjmc: thanks! Couldn't have done it without you. You helped provide the last piece of the project.
    F8L: it was pretty straight forward. Ill look through my pictures but I don't think I have any good shots of which wires to splice into. Maybe I can draw arrows to point it out easier.
    Plus IV: I patiently sourced my items mainly on eBay over the last 5 months. My last piece I got on here from Peter. Well worth it!
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,271
    Palmdale, Ca
    Nice job on the swap.
    F8L......the H11 low beam plug & the parking light plugs are the only 2 that would need to be changes. On the LED headlight, these wires are combined into 1 connector. There is a halogen to LED conversion adaptor that is available on yahoo Japan auctions but the cost of it without s&h is close to $90 USD & I'm not aware of them available in the US. That being said its not necessary to keep the OEM LED headlight connector. It can be cut off & replaced with the correct H11 connector & the same for the parking light.
    F8L likes this.
  8. bino
    bino JDM ZVW30
    1,348
    701
    SoCal 91739
    great job on the swap... I myself will be doing this swap.... I already have the LED lights (JDM) and I have the conversion harness/adapter as well....
    Dylan Doxey likes this.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    350
    Austin, TX
    Can you show a shot of the beam pattern?
  10. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Sean hit it right on the head. I have the left over harness still, and can take closeups of that. Basically on the stock LED harness you only need to tap into the black (-) and red (+) wires. I cut up a H11 harness left over from my HID kit to make this connection. The side parking light from the LED light (I guess they changed it for the 2012) was a little larger, so I trimmed it down with my dremel. Overall, these are the only 2 mods I had to do to mount this baby.
    bino like I said earlier... The JDM's look sweet! The harness should make installation basically PnP. What a difference a little orange (or lack of) can do.
    Jonny Zero I'm still at work (and charging). I'll take a picture in front of a flat wall when I leave tonight and upload it.
    F8L likes this.
  11. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Couldn't find a flat wall so I just took I'm front of my garage...
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,271
    Palmdale, Ca
    Looks good genetiix. How far away from that wall were u?
  13. leeb18c
    leeb18c Active Member
    272
    198
    SF Bay Area
    Gene, Congrats!! Looks very nice. I always wanted the LED lights. Now I need to start stalking ebay. :)
    Do you mind telling approximate prices on parts you bought? I see dealer prices on LED headlight alone are $500+ each and that's without the ballast/control module. Thanks.
  14. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Thanks Winston. The headlights were a huge range in price. On average I paid 185 each. The ballast I got for about 100 each. Throwing in misc parts to repair the lights and wires, the total came out to ~600.
    Goodluck with ebay! I was closely monitoring it for months for my last headlight. I finally though about placing a wanted ad on here. A couple weeks later... They are mounted on the car!
    lensovet and leeb18c like this.
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    350
    Austin, TX
    Thanks for the pictures. Looks like the driver side is aimed a tad higher than the passegner side. My Five is the same way from the factory and it had me wondering. Pictures in thiss thread: Factory LED Headlight Aim | PriusChat
    May be this is all intentional?
  16. somebody7
    somebody7 Member
    147
    36
    Austin, TX
    wow, thats a great price. I guess I need to stalk ebay more often. I would have definitely bought that first if I could get them at those prices. thanks for giving the pricing.
  17. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    I think it's even. I was up on my driveway alittle crooked. Ill double check it in a flat surface in the next couple of days.
  18. lensovet
    lensovet Not your typical youngin :)/BP Brigade 207
    2,606
    489
    Sunnyvale CA
    What would it take to make these lights auto-level, by the way?
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,271
    Palmdale, Ca
    As far as I know, there its a way unless ur Prii already came with it.
    U can go with a manual adjustment.
  20. lensovet
    2,606
    489
    Sunnyvale CA
    but i mean, all it is is just an assembly and a motor of some sort right? shouldn't it be possible to install those parts and wire them up?
Loading...
