LED Headlight Conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by genetiix, Sep 3, 2012.
  1. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    no issues on mine... but I'm in SoCal.. we really don't get that very cold weather that would need the headlight washers to clear the headlight lenses........ ;)
    I just put the covers of the washers on mine..... (y)
    sfv41901 likes this.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Two words: Southern California.
    The rear wiper is similarly useless, hence the rear wiper delete.
    Daigi_ and sfv41901 like this.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Bino & 32kcolors pretty much summed it up. :D
    VS980 4G ?
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    VS980 4G ?
  5. hermit375
    hermit375 Junior Member
    Lancaster Co. Pa.
    Now it's been sometime how's the LED change working? We have a 2010 that's eating low beam bulbs and instead of Toyota's wiring "fix" and or HID's looking at LED's which should have gone down in $$ and more out in circulation
  6. Mark in NY
    Mark in NY Junior Member
    23
    Long Island, NY
    I am also very interested in LED bulb change-out to convert from filament to LED..
    The Oracle and GTR LED H-11 replacement bulbs seem to be the better than the rest but I am reading a few conflicting reviews on them.
    Anyone here have experience with them?
  7. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Lights are holding up great. Performing like it came from the factory. Zero maintenance. It still has that wow factor every time I see it. :]
  8. hermit375
    Lancaster Co. Pa.
    Thanks for replying -- many talk of the headlight issue with 2010/2011 and the service bulletin that has a harness hack job Toyota came up with but don't say which direction they took and the results --- so others can follow or do different.. Our dealer was more than willing to apply the "fix" for a hefty $$$. And some have said the HID conversion at times flicker or delay coming on.. LED's have come a long way and I believe I'm headed in that direction. It seems to solve a lot of issues.
  9. FinToy
    FinToy Active Member
    145
    141
    Finland
    Hello gentlemen,
    I just found this (very old) topic while browsing for help. I happened to acquire a pair of led lamps for my 2011 Prius but wasn't totally sure how to fit them in. I have a pair of 2016 Auris ballasts that seem to be usable but since there are 3 separate lights in the lamp I wasn't sure what those are.
    My Prius is an EU spec and has halogen lights from the factory. It's quite clear, there's the parking lamp, short beam and long beam but in the LED lamp there's one more. What is is used for and how should it be connected? Thanks for any assistance.
  10. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The LED lowbeam consists of two mini projectors per side.
  11. FinToy
    145
    141
    Finland
    Wow, the answer was that simple. Thanks a lot! :)
    Burna J likes this.
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    No problem. :)
    Before and after pictures in the first post show single halogen lowbeam projector in the original headlight, and dual projectors plus reflector highbeam in the LED headlight housing.
  13. FinToy
    145
    141
    Finland
    Hello there! Since I didn't get too much attention with my topic I need to ask you here @genetiix
    Did you have a connector like this in your LED lamps? How did you connect the power there? Thanks!
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U have to buy an adaptor like this from Japan
    Or cutoff the connector on the headlight & splice on a H11 connector & the parking light wire from ur halogen headlights
    iPhone ?
  15. FinToy
    145
    141
    Finland
    What if I decide to go easy and just cut the wires. How to do the wiring in that case? I believe the parking light connector can be moved from the old lamp to new one so I just need to deal with the short beam. But there seems to be 3 wires going for the short beam, why?
    Or does anyone have a link where to order those adapters? Thanks!
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The blue wire is not used. It sends a can-bus signal to the BCM. If a headlight stops working it causes a yellow triangle on the DIC. Sins ur Prii isn't equipped with LED headlights, it won't use that blue wire.
    Here is a link however they have blocked it. Past history has shown that they will not unblock
    ZVW30プリウス ハロゲン⇒前期後期LEDヘッドライト 変換ハーネス /【Buyee】 "Buyee" 日本の通販商品・オークションの代理入札・代理購入
    I might have an extra set I can sell u. I'll pm u if I have it.
    iPhone ?
    #56 sfv41901, Mar 27, 2016
    FinToy likes this.
  17. FinToy
    145
    141
    Finland
    Wow. Too simple, again.
    That would be cool, thanks! I'm waiting for your PM.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Pam just sent
  19. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Sorry for the necro. I found one LED headlamp on ebay in servicable condition and decided I would play with it. I am trying to locate the mating connector for the headlight, to make my own adapter harness. 103096_12814359_1133068753410104_9115232678358493625_n1.jpg Pigtail-27.jpg
    Dylan Doxey likes this.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ur best bet for this will be at the dealer where u can buy the connector & matching terminals.....or a junk yard.
