LED Headlight Conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by genetiix, Sep 3, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U don't need to pull the whole bumper off but u do need to move the 5 clips & 2 10mm bolts on the top, 1 clip / 1 screw in each wheel arch & 1 clip under the bumper just in front of each wheel. Place a small box under the bumper so that u can tilt the bumper forward & rest it on the box. This will give u enough clearance to swap the headlights
    Dylan Doxey and trentofdestiny like this.
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Sorry for thread jacking lol. So this happened last night: IMG_5636.JPG IMG_5637.JPG
    I only did one side, the other side is HID. Still waiting on some hardware bits from Toyota for the right side unit. Seems awesome though.
    iPhone ?
  3. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    You'll love them. :)
    sfv41901 likes this.
  4. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I think I do, but don't want to judge just yet because of still having the right side still be HID
    iPhone ?
    Dylan Doxey likes this.
  5. trentofdestiny
    1,104
    227
    Harrisburg, PA
  6. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    So you scoured eBay for Plugin Advanced headlights?
    I might do the LED conversion but using the chrome housing ones.
  7. trentofdestiny
    1,104
    227
    Harrisburg, PA
    That is correct. Easy to find one cheaply, hard to find a matching pair. Seems that LH lights are damaged less than RH ones.
    iPhone ?
  8. submarshall
    submarshall New Member
    Guam
    I'm working on this same set up on my Prius V two. can you please let me know how you found the adapter and maybe a part number. Thanks!
  9. TeURaS
    TeURaS Junior Member
    Finland
    Hello. Im new to this forum and bought a 2010 Prius (zvw30) couple of weeks ago and now I decided to upgrade it bit by bit. Where can I get this LED headlight conversion? Can I just buy these headlights from ebay? Is the install simple bolt on? Do they have automatic height adjustment?
  10. trentofdestiny
    1,104
    227
    Harrisburg, PA
    You can buy the lights on eBay just make sure you are getting both the same style. Also make sure the computers are available. 2010-2011 headlights use the computer that’s like a piece of aluminum about the size of a piece of toast. 2012-2015 headlights have a smaller module with a plastic cover, more importantly they have a different connector.
    You will also need to make a conversion harness for the wiring but the headlights themselves will bolt right into the car. No, they will not have automatic leveling, but should be aimed from the last car they were on. The auto leveling system uses a computer, switch on the dash, and rear suspension height sensor, so there’s no way to get just the wiring for that. It’s included in the cars main wiring.
    iPhone ?
  11. TeURaS
    Finland
    Ok. I live in Finland and here it is regulated that if you have xenon headlights they must have auto leveling. Then I will just stay with the original H11 / HB3 headlights and use H11 Led kit and buy a Osram Nightbreaker Unlimited HB3... Shame....
  12. trentofdestiny
    1,104
    227
    Harrisburg, PA
    That is a shame. LED is not xenon but I doubt the law makes that distinction. An H11 LED kit will give your projectors a cat’s-eye look just so you know.
    iPhone ?
  13. TeURaS
    Finland
    Yep. I already have H11 led-kit and Led parking bulbs and it looks really cool. Only problem is humidity inside the headlight wont dry out...
  14. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Best way to deal with that is take the headlight inside your house and leave the bulbs out for a couple days and let the AC or heat dry it out. Not always feasible to do so though.
    iPhone ?
  15. TeURaS
    Finland
    Is it hard to take the headlight apart from the car?
  16. trentofdestiny
    1,104
    227
    Harrisburg, PA
    No, you just have to take the inner fender liner loose and remove the bumper fasteners from the top of the grille all the way across then there’s a headlight bolt behind the bumper and a headlight tab behind the grille that clips into the metal
    iPhone ?
  17. FinToy
    FinToy Active Member
    145
    141
    Finland
  18. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Any of u guys who knows what the connector for the 2010-2011 LED headlight is called? im looking for just an extension for it. Since im adding DRL`s i need to hook one of the wires from the DRL to the headlight so the DRL knows when to shut off. So yea... do u guys know what the connector on the 2010-2011 LED headlight is called? or if its any extension harnesses for it? i really dont wanna slice up the OEM cables to fit the DRL wire... id rather have an extension i can hook things up to and stuff so i dont ruin the OEM wires.
  19. trentofdestiny
    1,104
    227
    Harrisburg, PA
    There are no extension harnesses. You can make one by purchasing male and female connector halves and terminals. It will probably cost over $100 though
    iPhone ?
  20. MagnusAG99
    673
    521
    Norway
    i see.. guess i will just use scotch locks to hock them on the positive wire then
