LED Headlight Conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by genetiix, Sep 3, 2012.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,057
    201
    Harrisburg, PA
    Yes the side marker socket will hang. And you can either get a mating plug for the triangle plug or cut & splice. But that should use the same terminals as the big plug.
    iPhone ?
    freedom1725 likes this.
  2. freedom1725
    freedom1725 Member
    70
    141
    Palo Alto, CA
    Thank you so much for the info. Let’s start shopping lol
  3. trentofdestiny
    1,057
    201
    Harrisburg, PA
    Whatever Toyota wiring you get your hands on, check the connector for the part number, find it in the wiring book, and it will tell you if the terminal is correct for what you need. If you were here I'd give you some to get you started lol
    iPhone ?
  4. route246
    route246 Junior Member
    30
    SF Bay Area
  5. trentofdestiny
    1,057
    201
    Harrisburg, PA
    I tried a similar one from XenonDepot. They weren't as bright as my Morimoto HID kit o had at the time, and it gave the halogen projectors a cat's-eye look, so I got rid of them. Eventually I got the Toyota LED headlamps.
    iPhone ?
  6. route246
    30
    SF Bay Area
    I am not as concerned about "the look" as I am about the projection. We have two other vehicles ('17 Ford Focus RS, '18 RAV4 Hybrid Limited) that have bright LED headlights and they really light up the road well compared to my stock Prius bulbs. I want bulbs that will really illuminate the road.
    This kit from Precision LED seems to be simple and complete. I replaced my horns so have experience taking the front bumper mounts apart so I'm not averse to a little disassembly and reassembly but I just want something that works.
    LaJay007 likes this.
  7. trentofdestiny
    1,057
    201
    Harrisburg, PA
    I don't think they will be bright enough for you but that's subjective; the only way to find out is to try.
    iPhone ?
  8. route246
    30
    SF Bay Area
    Thank you very much for the feedback. I'm not expecting perfection but if it improves a little I'll be OK with it.
  9. freedom1725
    freedom1725 Member
    70
    141
    Palo Alto, CA
    It terms of increasing brightness, I would say fog light kits may do better job than LED bulb. I am having Opt7 LED kits on both ZVW30. The LED improves but not a lot. But with fog n without fog makes a big difference.
    I’m switching to OEM headlights because my halogen is getting moisture inside. I’ve been told that the OEM set is way better than LED bulb. Of course, the price tells the differences lol
  10. PutPutMobile
    PutPutMobile Senior Member
    302
    545
    Buena Park, CA
    These LED's doesn't show how much lumen output it can produce on each bulb.. If it's 8,000 LM total or a little more, then it's good.. if it's under 8k LM, then it sucks cos you can't see as far of a distance.. I haven't watched the video ad yet though..
  11. freedom1725
    freedom1725 Member
    70
    141
    Palo Alto, CA
    Just wondering if every plugs in the engine bay for any toyota that have similar size use the same water proof type 2-3 type terminal?
    I’ve been looking on a 2004 corolla wiring manual but couldn’t tell which are suitable for me.
    Would u mind giving me a hand on getting a better clue on that, please?
    Thanks
  12. trentofdestiny
    1,057
    201
    Harrisburg, PA
    You kinda need to have the connector in your hand to read the numbers on it. I'm not sure that you can find a connector shell number from a wiring diagram, although it should give you a diagram of the connector pins. As far as the 04 Corolla, I'm sure there's a few connectors with suitable terminals, just not sure which ones.
    iPhone ?
  13. hw30_
    hw30_ New Member
    Where can I buy this headlight housing?
    can
  14. trentofdestiny
    1,057
    201
    Harrisburg, PA
    eBay or Toyota. You will most likely have to buy the computer separate. And don't forget the custom wiring if you are putting it in a car that didn't originally have it.
    iPhone ?
    hw30_ likes this.
  15. hw30_
    hw30_ New Member
    Sorry but new to this... what is the housing called? I’ve tried eBay but I’m confused too many options there and without the light can’t see the led brow. And fog lights I only it for see Prius v is that going to fit a Prius 3. Thanks
    Burna J likes this.
  16. trentofdestiny
    1,057
    201
    Harrisburg, PA
    Just type in something like "Prius (headlight,headlamp) led". You'll have to learn the shapes of the different housings but if it has 2 projector "eyeballs" it's led and if not then it's halogen. The one with 2 eyeballs and a square high beam bulb reflector will have the eyebrow, but there are 2 different ones. Some have gray inside and some are blue from the plugin model. The gray and blue are just for looks they don't affect anything. I don't believe the fog lights will fit different models but I don't know as I don't believe in them lol.
    iPhone ?
    hw30_ likes this.
  17. JamesK94
    JamesK94 Junior Member
    32
    32
    Phoenix
    So I just received my LED headlight assemblies tonight and I decided to install the bulbs before I install the assemblies themselves to make my life a bit easier. Thankfully I did cause I don’t know what I’m looking at.
    So from what I understand, the 2 smaller lights on the outside of the car are the normal headlights and the bigger one towards the center are the brights. If this is the case, how do I change out the normal lights? Cause I can easily change out the bigger one and the 2 small lights (which I presume are the parking lights) but not the 2 actual headlights. Do I have to take apart the assembly in order to install the lights?
    [​IMG] [​IMG] [​IMG] [​IMG]
  18. trentofdestiny
    1,057
    201
    Harrisburg, PA
    You can't change out the "normal lights" (low beams). They are built into the LED headlight, hence its high price. Only things you can install are the front parking bulb, side marker bulb, and high beam bulb.
    iPhone ?
  19. JamesK94
    32
    32
    Phoenix
    Ahh okay. Well, that works for me/explains it!
    Thanks!
  20. trentofdestiny
    1,057
    201
    Harrisburg, PA
    You're welcome! Any questions about wiring I can try to help with also.
    iPhone ?
Loading...
