LED headlight mod for base PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by stackcheese, Aug 14, 2012.
  1. stackcheese
    stackcheese Junior Member
    50
    Pasadena, CA
    I've been reading how the pip advance and V LED headlights are sort of disappointing/step sideways compared to the halogen rather than a step up and was curious if there's an aftermarket HID/LED option available for the PIP base mode?
    If not how difficult would it be to mod this myself?
    Thanks
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Where in the world did you read that?
    My Prius upgrade from 2010 halogen to 2012 LED was dramatic. I'm delighted how great the illumination is, and I've been be fan of projector-beams (lens lights) for over 20 years.
    I've also recently seen HID with project-beams. Those are nice too, but not as good as LED.
    parnami likes this.
  3. stackcheese
    50
    Pasadena, CA
    i see yeah searching based on the gen3 prius suggest i should look into the following:
    Morimoto
    Xenon
    Does anyone have any input in regards to the PIP install?
    Is it difficult/easy?
    How would it affect my car warranty (toyota standard)?
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Its super easy to install, basically plug and play. The hardest part will be finding a mounting spot for the HID ballasts. There's lots to read, DIYs, pictures, etc in the Accessories and Mods subforum.
    Xenon Depot and Morimoto kits are highly rated on PC. I personally have DDM ballasts and Morimoto 5000K bulbs. Its a good combo for me.. great price.. and DDM has a lifetime warranty on their ballasts (and they are relatively close to me). If you're anal about the light cutoff, then you may want to look into an projector retrofit. The cut off on the Prius headlights isnt perfect. But its not the worst cut off in the world either.
  5. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Love my LED lights.
    mnml likes this.
  6. stackcheese
    50
    Pasadena, CA
    fineshed the mod today after work. took much longer than expected, though this was my first time ever really working under the hood..
    ended up getting the morimoto's... unfortunately i do get the weird lower coil shade problem, but it doesn't really bother me.
    installed the heavy duty relay too it was kind of confusing at first as the kit came with a few wires that i'm currently not using... not sure if i installed them correctly if anyone knows of pictures of a morimoto relay+h11 install please post as im curious about the additional wires that are plugged no where...
    the lights seem to work though
    if anyone wants details/photos let me know it was a bitch to mount the ballast, and honestly i dont think where i mounted them will be permanent as the metal bars that came with the morimoto's look fairly flimsy.
    s
  7. M-PRIUS
    M-PRIUS New Member
    I have a 2011 Prius Five and I love good lighting. I am thinking of getting a 2012 Plugin entry level car without the LED.
    Can I buy the LED headlights from Toyota parts department and install plug and play or will be difficult. Did anyone do it?
    Thanks.
  8. lensovet
    2,615
    496
    Burlington, NJ
    Not really. The LED lights, apart from the headlight unit itself, also have a Computer assembly to control the LEDs and a leveling motor and associated components.
    Also, the parts alone will run you about $1800.
  9. SJ PiP
    SJ PiP Member
    190
    35
    same here. great visibility and nice blue tint
  10. Johnny C
    Johnny C Member
    162
    16
    Boston
    Damn, that's a pricey set of light, but they look damn good.
  11. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Maybe I don't know what I am missing but, I find the 2012 base PiP lights work great.
  12. CharlesH
    2,796
    1,163
    Roseville, CA
    The LED lights pull a LOT less power. I haven't seen the actual wattage numbers vs. the standard halogen lamps.
    lensovet likes this.
  13. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Anyone have the numbers for LEDs, HID, and halogen.
  14. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    some HID info....
    XENON H.I.D. lamps are 35 watts while traditional halogen bulbs are 55 watts. Even though XENON H.I.D. lamps draw less current, they produce 3 times the light output as the higher wattage halogen bulbs. Increasing the wattage will make the bulb a little brighter but still much dimmer that the XENON HID lamps. Also, AMPS = (BULB WATTS X 2) / BATTERY VOLTAGE OUTPUT (12). So as you increase the wattage on your bulb you increase the current draw on your entire electrical system. This is critical in motorcycle applications and produces a lot of heat, which can also be a problem in anything.
  15. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    I did this mod recently. Pretty much straight swap. The only thing you'll be missing out on is the auto leveling feature (which you never had with halogens anyways). The hardest part is to find the parts at an affordable price.
  16. lensovet
    2,615
    496
    Burlington, NJ
    can you provide a write-up? I would be very interested in doing this mod personally.
  17. bisco
    51,154
    so, rounding, if my halogens are 100w, my 30 minute commute is 50 watts? or 50wh? and if so, about 2% of my battery capacity?
  18. lensovet
    2,615
    496
    Burlington, NJ
    Here's the relevant thread in the gen 3 forum: LED Headlight Conversion | PriusChat
    Note that gene was able to get the parts for roughly $600 by monitoring eBay over the span of 5 months. Also, looks like things changed a bit in the 2012 refresh and some minor sanding down was required to get the lights to fit.
