Led headlights h4 9003
Discussion in 'Gen 2 Prius Accessories & Modifications' started by waldox, Nov 19, 2018.
  1. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Yes, thanks, but I’d rather go to LED not Halogen. Once and done.
    Will probably try it eventually if I can see someone personally who’s done it and not just a vendor wanting to sell me a LED kit.
  2. PriusCamper
    PriusCamper Senior Member
    13,353
    5,398
    Pacific Northwest, USA
    As I've already said, once you buy the headlight cases/lenses for halogen, you have endless LED bulb options to choose from. I've done this conversion more than once and you simply need to buy these: Headlight Set For 2006 2007 2008 2009 Toyota Prius Left and Right 2Pc | eBay and Headlight Socket Dorman 84790 and the re-wiring is real simple and will walk you through it when that time comes.
    kenoarto and Another like this.
  3. Another
    1,819
    520
    Naples, Florida
    Thanks yes I saw that it was eventually LED, I’ll look at those. Was not wanting to tear things apart without experience on putting it back together. May have to though.
    kenoarto likes this.
  4. dpower
    dpower Member
    98
    49
    Katy Tx
    I have found The Retrofit Resource has some of the best products. Take a look at the morimoto 2 stroke it’s a extremely well made and adjustable. Comes with all the gaskets you could need. If your setup requires extended covers the sell those as well. It uses a adapter to fit the factory wiring.they have them for both hid or halogen base housings. Great led headlights.
    I’ve got the new gtr white lights for backup to install this week along with turn signals and resistors. The brake lights were a bit of a pain to find one the illuminated correctly. I’m using the gtr 2.0 carbide light. works well.
    #24 dpower, May 30, 2022
    kenoarto and PriusCamper like this.
  5. Another
    1,819
    520
    Naples, Florida
  6. James Analytic
    409
    63
    Michigan
    I soldered my first HID to Halogen conversion.
    My second HID to Halogen conversion I used wires, tape and the goal of spade connectors. This second design was so that in the future sale, I don't have to potential cut and resolder the HID connection back.
    My next in line HID to Halogen conversion has the connectors from a broken HID assembly so I can make plugs from the HID PCB and connectors as well as the Halogen pigtails.
