LED inside light's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Jan 31, 2008.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    Well, this is a confusing response (to me). Watts are not a measure of light output. So, the real question is; is the light output of these cheap LED replacement bulbs dimmer than the OEM incandescent bulbs? I know that you (darrell) have the super quality, hand made LED bulbs which are better then the OEM bulbs, but are these cheap knock offs better or worse than the OEM bulbs.
  2. Flying White Dutchman
    4,376
    313
    today i also replaced the parking light
    buth am not happy with it!
    its just a 1 led bulb 600mcd so i sm goinig for the 8000mcg 6 led bulb
    then i wil use them for the backlight to and maybe the licence plate lights
    some pics below
    the left the led en right the oem
  3. darelldd
    6,059
    389
    Northern CA
    First off... I need to apologize for being so negative on these import drop-ins. Problem is, I've just spent way to much on these over the years, and so few mfgs want to even try and make quality units. The name of the game is "cheap" and so even if somebody DOES make a good one, you'll be hard pressed to find it except by accident. OK... so that's out of the way.
    I wish I had an answer for you, but alas, I do not. Using 5 or 3mm LEDs to make these things allows the product to be cheap - but you likely won't be happy with the output, or the durability of the unit. They typically overdrive the snot out of these things (which pushes the light frequency toward the angry blue) - and they also are almost never regulated. V spikes will kill them.
    Correct. Sorry for any confusion. I gave two answers. The first part was about the concern about these LEDs units consuming more than 5W. That has nothing to do with brightness, just energy consumption. My answer is that there is no way they can dissipate 5W. If they tried, they'd burn up instantly.
    And the other part of my response - my comment - was that yes... the output of the cheap LED replacements will be dimmer than the OEM incandescents.
    They'll use less energy and they will produce less light. The ones that I was making used less energy and produced MORE light.
  4. Flying White Dutchman
    4,376
    313
    this picture was made in daylight
    its a elcheapo T11 6 led
  5. PKT
    PKT New Member
    West Palm Beach
    Was this a drop in? no mod? The cargo area is the only
    led I've not been able to find......have a link? :)
  6. Flying White Dutchman
    4,376
    313
    yes
    i used these in a 6 led variant
    Super Bright LEDs - Festoon Base Bulbs
  7. Flying White Dutchman
    4,376
    313
  8. Darkamek
    Darkamek New Member
    Greenfield,WI
  9. Flying White Dutchman
    4,376
    313
    ok
    today i got new ones
    8000mcd
    a lot better then the 600mcd from the firts time
    i think 800mcd is the minumum for parking lights
    i wil make a picture when its dark.
    only can not use these for backlights and licence plate lights because there directional
    and then the reflector off the backlight is not working
    i need some led that are bydirectional...
    shame i only found those in the US and need them in the eu... for a small price that these leds cost i not going to pay for shippng that is a lot more then the leds only.
  10. Flying White Dutchman
    4,376
    313
    here are the new one's
    good for inside and parking front light
    not for back parking lights
  11. Tideland Prius
    16,675
    whoa that's bright
  12. Flying White Dutchman
    4,376
    313
    it looks better then it is;)
    it whas realy dark. so:D
    buth this realy gives good light... but JUST good anough more wil be better to compare with the origional light bulb
  13. siliconhybrid
    siliconhybrid Member
    121
    Bay Area California
    where did you buy these?
  14. justin858
    justin858 New Member
    SD
    yes, where did you buy these?
    thank you
  15. Flying White Dutchman
    4,376
    313
    Eu shop not in English:(
    thats wy i added the pictures of the package and name of the iltayen maker! so maybe you can find some dealer
